Question about Whirlpool MH1141XM Microwave Oven
Over the range microvawe Whirlpool MH6140XKQ1
MY MICROWAVE IS MAKING A LOUD NOISE AND IT IS NOT HEATING UP THE FOOD AT ALL.
WHAT CAN CAUSE THIS TO OCCUR?
  • syfax Jul 29, 2008
    After reading the safety warnings, I simply decided it was not worth the risk. So, I went out and bought a new microwave oven!
    All set!
    Thank you for your assistance.
    Sincerely,
    Syfax
  • Whirlpool Master
  • 9,098 Answers
Either a shorted high voltage rectifier diode or magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My microwave is making a very loud noise and not heating food.
Try plugging it into another outlet and see what happens.
Jun 27, 2017 | Frigidaire FGMV174K Microwave Oven
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Kenmore Over the Range Microwave making buzzing sound and not heating
    This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
    Jul 18, 2012 | Microwave Ovens
    We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
    The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
    Mar 24, 2011 | Maytag MMV4205 Microwave Oven
    Microwave oven: GE Spacemaker 1400 not heating. Model number JVM1430AB001. Need guidance on troubleshooting and repair of unit. Thanks!
    If the oven is making a loud buzzing noise when you try to warm food and the food remains cold, it usually means that the magnetron has failed. Not usually worth fixing since the parts alone can cause as much as a new oven.
    Oct 04, 2010 | GE Microwave Ovens
    GE spacesaver II making loud noise and is not heating up food
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Our microwave oven started making a loud sound and quit heating
    Basic Microwave Oven TroubleshootingTips
    heatman101==]-]=-
    Feb 14, 2010 | Emerson MW8107WA Microwave Oven
    I have Whirlpool GH 7155XHS-1 and it started making loud noise when used. Food still gets warmed but makes a loud noise when food is being warmed. Started a week back. Please let me know if you know the...
    The unit is failing. Probably the megatron tube. IT can pass quickly or slowly. I had a Sharp that lasted about a month before conking out on me at a most in opportune time: Dinner for 8 and it was late! Take caution. Start shopping.
    Nov 08, 2009 | Whirlpool GH7155XHS Microwave Oven
    Microwave not heating food and is making loud noise.
    You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
    Jan 31, 2009 | GE JVM1860 Microwave Oven
    Whirlpool MH1141XM Microwave Oven Logo
    251 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
