Question about Whirlpool LER5636P Electric Dryer
No heat coming out of my dryer it spins and there is good source of power...
  • 5,911 Answers
Please read through the following link to see if this helps you:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require further assistance in diagnosing your problem and/or ordering any necessary replacment parts, post back and let me know. If the model number you listed this under is not correct, please post back with your correct number. I hope this helps you.
Posted on Jul 25, 2008
    President:
  • 1,779 Answers
How old is the dryer? The heating element is probably no good.
It's possible to fix it yourself. Make sure it's unplugged before you start. You might want to check a parts store, or online to see what the heating element would cost. when this goes bad, the dryer will still spin, and the heat stops instantly. It's a little tricky taking the panels off, but there's not too much to a dryer. An electric motor that powers a belt to make it spin, the heating element, metal sides, top and bottom. Good Luck! Countrycurt0
No heat, just a slight glow coming from the heat source
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 14, 2010 | Whirlpool LER5636P Electric Dryer
LER5636P Electric Dryer: WILL NOT SPIN...
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
May 18, 2010 | Whirlpool LER5636P Electric Dryer
LER5636P Electric Dryer: dryer won't heat...
check power to unit ,,,,,then check thermofuse and door switch
May 17, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
There are a number of things that can cause these problems...
Check out this tip it will help you...
heatman101
Mar 29, 2010 | Whirlpool LER5636P Electric Dryer
WHIRLPOOL ELECTRIC DRYER.MODEL # LEQ9508PW1. DRYER IS NOT SPINNING. MOTOR IS HEATING AND RUNNING FINE. I OPENED TOP AND BELT IS ON BUT LOOSE. BELT IS NOT BROKEN JUST LOOSE. WHAT COULD THIS BE?
You will have to go farther and remove the drum.
I believe your problem is that the belt has slipped off of the motor, or has slipped off the idler arm with pulley brackett.
Good Luck,
I hope this helps
Oct 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer LER4634PQo won't heat up
if it spins
its more than likely just your heat package
ive included the national part number
you can order it through sears
4391960 42.00
Oct 06, 2009 | Whirlpool LER5636P Electric Dryer
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Dryer no heat coming out
Jul 21, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
