Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
Can't print to 1410 after I upgraded to Leopard
I upgraded my iMac to Leopard last night, and now I cannot print to my 1410. It was working fine prior to the upgrade. I have tried reinstalling the drivers from the Leopard CD, resetting the printer list, and re-adding the printer. It looks like it will print, can "see" the printer enough to tell me ink levels, but goes it "idle" before actually printing. I cannot print any .pdf files since upgrading to Leopard. Regular files from Pages print just fine. Any application that handles .pdf files just crashes whenever you try to print from it (Preview, Acrobat Reader, Quicktime, etc.).
I have sent error reports to Apple, so maybe they will find the problem within Leopard.
I am using a printer over a wireless network with Bounjour as the intermediary. My printer is an HP 1610 all-in-one.
  • mayamp Feb 01, 2009
    I have a similar problem.  I upgraded to Leopard and now my HP PSC 1610 All-in-One Printer/Scanner/Copier won't scan.  When I try to scan it says "No Scan Options.  You need to install or run device software for feature."  I re-installed, so no avail.  The printer is configured in my computer.  It worked without problems for years before I upgraded.  Help!
I believe I had a similar problem. Try this:
Go to System Preferences > Print & Fax > '+'
Select the Epson 1410 and then under Print Using go to Select a driver to use the Epson Styls Phot 1410 - Gutenprint v5.1.3
I hope it helps.
Posted on Aug 17, 2008
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
Jun 24, 2011 | Apple iMac G5 Desktop
I have imac. and i want to change his operating
Yes it is very easy to do as you are running a Mac with Intel Processor. You have Mac OSx Leopard with updates 1,2, & 3. To upgrade to Mac OSx Snow Leopard you must buy the upgrade. Go here: http://www.apple.com/macosx/ On the top right click (Buy Now) You will have to pay $29 which is a bargain. Once you get the upgrade on CD simply follow the directions for the simple upgrade. I did the same thing when Snow Leopard came out. It is well worth the $29.
May 29, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Print overrun
probably the automatic upgrades of drivers and so ..cause the problem ...it might just replace your driver with a version they consider updated...and which just dont work with your ....printer ...try to reinstall the driver ( clean ) and if it works ..it means that this is the problem ...
Oct 03, 2009 | Brother HL-2040 Laser Printer
I only get a black sheet of paper if I copy with my hp 1610
you will need to download the driver for leopard after you remove tiger
Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Bad print quality ? very, very pale
in finder (Desktop mode) click on help,type in print quality see if theres anything that can help .
Apr 30, 2009 | Epson Stylus Photo R1800 InkJet Printer
Airport Express, Bonjour Printing Does Work With Leopard
In the setup of the Airport network settings, you have to make sure that AppleTalk is actually turned on (or the box is checked). When using Mac's with Leopard and you use both the ethernet port and airport off and on, the OS tends to deactivate AppleTalk. Its not a set thing, just random.
Jun 27, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
You need to update your printer software. Download and install from this link;
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-58037-1&lc=en&dlc=en&cc=us&lang=en&os=219&product=441115
Once it is installed I suggest that you open system preferences (found by clicking the apple in the top left) and go to print and fax and delete and readd the printer so it will pull from the most recent drivers.
Feb 11, 2008 | HP PSC 1410 All-In-One InkJet Printer
359 people viewed this question
Seeker5211
Seeker5211
