Question about Protron PD-DVR100 DVD Recorder
No sound from the s-video cable
I am using S-Video cable from my DirecTv box to the DVD and also I have a composite cable from the video/audio out of the DVD to the TV and I have no sound. What could it be or what should I do?
  • Erin31383 Jan 29, 2009
    I have connected an S-video cable from my DVD player to my Sony TV.  I have also connected the audio cables (red and white) from the DVD player to the TV.  All cables are connected to Video/Audio OUT on the DVD player and Video/Audio IN on the TV.  There is video, but no sound.  Do I need a receiver to hear the sound?  Please help!
  • Anonymous Feb 28, 2009
    exactly same problem with same type equipment there is nothing in the manual.....
    Problem Solver:
  • 4 Answers
HOWDY-WITH "S-VIDEO" YOU ALSO HAVE TO HOOK UP AN AUDIO OUT TO ANY TV/AUDIO SYSTEM/ETC.--PLEASE READ THE OWNERS MANUAL---SARGE
Posted on Jul 27, 2008
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
I am trying to connect a wii to an onkyo tx-sr304...i have a directv satellite box and a DVD player connected to the component Video 1 and DVD connections and using to connect component out to TV...trying...
The pecking order for output video to your monitor forbids a lower quality video (composite (Yellow) being up-ticked to anything higher (your component out) (Page23).
The wii would be visible on the Monitor Out composite output (Page 24) to the TV.
Dec 26, 2010 | Onkyo TX-SR304 Receiver
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Feb 26, 2009 | JVC THD-50 System
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Protron PD-DVR100 DVD Recorder Logo
626 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
