I have a canon PIXMA MP830 office all-in-one scanner, fax,printer. It is not sending or receiving faxes. It will still copy and scan. I have checked the phone line and it is ok. What do I do next?
    New Friend:
I HAVE A SHARP UX 178 THAT WILL NOT RECEIVE A FAX OR SEND A FAX WHAT CAN I DO
Posted on Jun 24, 2013
  • 7 Answers
SOURCE: Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Posted on Oct 24, 2007
  • 106 Answers
SOURCE: Intellifax 4100 won't receive faxes
probably you not properly install a line cord,try to check.check it and this is 100%.if you still have problem try to conect the telephone on telephone line cord aand check the line is ok.
Posted on Feb 07, 2008
  • 2072 Answers
SOURCE: won't receive fax calls
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Posted on Apr 03, 2008
SOURCE: getting CHECK 5100 on a Canon Fax-JX300
FINE CARTRIDGE HOLDER OR PRINT HEAD BLOCKED
Posted on Apr 28, 2008
leroyal
  • 2120 Answers
SOURCE: Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Posted on Oct 21, 2008
How can your fax machine on your canon pixma mx397 work? steps please.. thanks!
For details check Canon Pixma Mx397 Manual. Turn on your your printer. Press "FAX" button from printer. Load the document you want to fax on platen glass. Customize scan contrast and resolution settings as you need. Use numeric numbers to dial receiver telephone number. Start sending. You document will be faxed successfully.
Aug 03, 2013 | Office Equipment & Supplies
Scanning problem
I checked with the Canon Help Desk and wass told to uninstall driver for the Canon MP830 (unplug the USB Cable) and thn reinstall it. Hint: make sure you have your disc to reinstall befoe you uninstall, just in case.
Feb 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
My fax is jammed and not printing does sender get an OK?
IF your scanner is working then you can send faxes it will stored in the printer memory and then send the fax..
Good luck...
Nov 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CANT SEND FAX THRU MY CANON MP830
you need to setup and set data for send and receive to be the same to use the same port!!!
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax problem
I can't receive faxes. I have a Canon MP830. Please advise what is wrong. Yhanks
Dec 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
108 people viewed this question
jasbo
jasbo
