Question about NAD 533 Turntable
Improving my NAD 533
I have had this turntable for several years and was wondering what i could do to improve its performance. I am a little confused with the modern turntable speak (you seem to have to buy seperate arms and the rest) so have been put off buying an upgrade for £500+ and have decided to spend the money on my existing one.
Any ideas. Cartridges perhaps?
  • pgafish Aug 15, 2008
    Thanks mate.
  • Anonymous Mar 18, 2014
    It sounds good, but I'm willing to spend the money to maximize the potential improvement.
  • 515 Answers
Well, I would suggest joining a Turntable, Audiophile, or Electronics forum. There are quite a few out there. All depends on which one you like.
There are plenty of cartridges out there which can provide optimal performance and sound. They range in price from US$50-$400 - all depends on your budget and requirements. I would suggest asking questions in the forums, as many of those people have already gone through what you are going through.
DJ Pro Audio
Posted on Aug 02, 2008
Does a Technics SL-J90 have a preamp?
This player does not have a pre amp. I'l send a link for the service manual, but don't try to change anything.
The element you use, is a MM or a MC (Moving Magnet or moving coil)
The MM gives about 100 times higher voltage, but still less than any modern amplifier can handle. The MC element only gives something between 0,2 and 1 mili volt.
Then if your amplifier does not have a RIAA correction, your preamp should have.
Just google around for MM and MC elements. My guess is you have the original MM element.
TECHNICS SL J90 Service Manual
Dec 27, 2014 | Technics Audio Players & Recorders
What are the most popular shapes of desks?
There are severalshapes that desk normally come in: straight (rectangle) desk, u shape, l shape,p shape, circle desks, and more.
Jul 25, 2012 | Furniture
Technics SL B202 doesn't maintain consistent speed. I have cleaned the unit's surfaces where belt comes into contact and it improved. i used a little lubricating spray on the speed control pot as...
From your description it sounds like the motor is the issue, it probably needs to be taken apart and cleaned and re-lubricated with phono oil if it still available. It is possible that time will improve the performance, but you probably should replace the turntable belt especially when it has been sitting for a long time without use.
Jun 09, 2011 | Audio Players & Recorders
I have a Technics SL-150 mk1 direct drive turntable in reasonable condition. The only problem is that the pitch does not stay steady. The pitch pots have to be adjusted constantly after start up as it very...
Normally sewing machine oil wouldn't be to heavy for this application, but if the pots were worn, the oil might have amplified the problem. I would search some of the audiophile forums online and avoid the Crutchfields' and other modern "know nothing" audio outlets. These were great turntables & "robust" is an understatement... With a little diligence I'm sure you'll locate replacement pots or another turntable as a "donor".(maybe Ebay???) Good luck on your qwest!
Mar 11, 2011 | Technics Audio Players & Recorders
I have Belguim Browning sweet 16 with a serial number 2s95067 was wondering what year it was made
Go Here:
for the answer to your question. The auto 5 had several number schemes during its production. Make sure you are reading the serial # correctly.
May 31, 2010 | HOT TOYS 16 Modern Firearms 3 Akm W Drum
I am wondering how to install the belt on the turntable
You wrap it around the protruding disc on the bottom of the turntable, then as you place it on, you hold the belt over the little post that is sticking up from the base of the player. Gently lower it and it is on.
Jan 19, 2010 | Sony PS-LX250H Turntable
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
Problem with connectors, no left channel
Your RCA leads/cables might be bad and need to be replaced.
Turntable Technician
Aug 23, 2008 | NAD 533 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search...
Feb 17, 2008 | Technics SL-1210 Turntable
Dishes stay wet after cycle
No drain hose routing has nothing to do with drying performance. The biggest thing that affects drying performance is water temp. Modern dishwashers use such a small amount of water is usually never gets very hot before the dishwasher has reached its full level. You can try to select hi temp wash and that should help. Also make sure that heat dry is selected. Also you really to purchase jet dry and install in dispenser. This will improve drying as well.
Dec 01, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
NAD 533 Turntable Logo
250 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
