SOURCE: I replaced the original two 250MB RAM with 4x1GB
Did you put in the right type of RAM? many times this will happen if the wrong type is installed or if one of the sticks is bad, OR if it's too much ram for the motherboard to handle. The older systems that run with SDRAM will only go up to 512MB.
SOURCE: hp pavilion a820n will not
Agree,
1) Could be a bad Power Cord
2) Could be that the inside of the computer is dirty. (Power UNPLUGGED from computer. Observe Anti-Static Precautions)
3) Could be a bad Power On switch, or a bad Power Supply.
There is a test to see if it's the switch, or the Power Supply, if you wish to know.
(The Power On switch is located inside the plastic Power On button, in the Front Panel. {HP term > Bezel}
This generic ATX power on switch I have found, fit's many computers,
http://www.directron.com/atxswitch.html )
The test involves bypassing the Power On switch.
IF when bypassing, the Power Supply comes on, the problem is the Power On switch.
IF when bypassing, the Power Supply does Not come on, the problem is the Power Supply.
The test does not directly involve the Power On switch. A jumper wire is used on the 24-pin ATX main power cable's connector,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300046&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443070
Scroll down the page to the motherboard illustration, and photo.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The jumper wire goes from the Green wire, (Soft Power On. Also abbreviated as PS_ON), to ANY Black wire.
ALL Black wires are ground wires.
There is a proper procedure for this, and it does Not involve any splicing, or cutting of wires.
Post in a Comment if you wish to know how.
If the Power Supply is found to be bad, just replace it. YOU yourself can do it.
I can guide you.
