Question about Motorola Mobility RAZR V3
Bluetooth connection my h605 motorola blue tooth is not being recognised by my v3 phone how do i connect the bt to the v3. any ideas?
    Brigadier General:
  • 7,752 Answers
Take it to a mobile store and ahve assistance there
Posted on Aug 21, 2008
How do I bluetooth photos from motarola v3 mobile phone to my pc,
i dont have acess to one of those computers but i will try my best to help you out.
click start, control panel,devices.then see if you find the bluetooth device.
turn on the blue tooth on the phone and use the discoverable function.
use the computer to search and try to connect to the phone.
when it is connected to each other the you can now transfer info.
to send the pics no:-
mark the photos on the phone
select send via bluetooth
search devices
select the computer from the phone
send it
on the computer recieve file and choose save location.
Alternative method:-
some bluetooth devices allow you to search the phone and take any device after connecting to it!!
Feb 27, 2010 | Motorola Mobility RAZR V3
Visor bt, i need a passkey code. i have no idea what this is
Yes had same problem. all the usual 0000, 1234 etc access to the device was denied...on the point of binning it.....However found the answer... Get your phone to the point where its recognised another device ie the bt visor , select and its asking for password. ...Turn on BT Visor BUT continue to hold main button for several seconds. There will then be another beep and light flashes alternately red and blue now insert 0000 into your phone and ok...this should then pair the devices.
Good luck
Jan 16, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Mazda bluetooth connection
delete all bt devices in your phone then try again
Oct 01, 2008 | Motorola Mobility RAZR V3
Unaable to connect bluetooth to phone
make sure the BT headset is fully charge.
  • press and hold the power button on the headset it will have a constant blue light indicating it is one
  • activate the bt in menu/settings/connections/ put the phone to search for the h/set once it have find it , it will ask you to enter the passcode which is 0000.
  • now you should be paired to he headset
Jul 01, 2008 | Motorola Mobility RAZR V3
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Motorola blue tooth
No problem, First you need to turn blue tooth on in your phone, menu>settings>bluetooth(sometimes it's connection>enable bluetooth. Then you have to tell your phone to search for a device I think that's under handsfree in the bluetooth menu. To put tell your headset to look for the phone make sure it's off. Then press and hold the power key until it starts flashing repeatedly, (if your headset has a flip mic you will have to flip it open as you are holding power) The trick is putting both the phone and headet into pairing at the same time. the phone should find the headet, you need select and it will ask you for a pass code, the pass code is 0000 . Hit connect and you are good to go. Good luck, if you need more details let me know what model headset and what model RZR. (V3, V3M,V3XX) L8R
Sep 17, 2007 | Cell Phones
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Blue tooth LED indicator
try going to back to your bluetooth settings and making sure you phones visibility or "find me" mode is turned off. This is a good idea anyway cause anyone can find your phone. Then consider most people don't change their passwords so hacking into your phone and reading your texts and looking at your pictures and even trade things back and forth from their phone to yours!!!
May 08, 2007 | Motorola Mobility RAZR V3
Motorola v3 razor bluetooth
Ok so your phone detects other people's phone in a limited range of area around you through your bluetooth, although your range doesn't really matter. So when you send your freind something through bluetooth does your light in the corner light up?, is your friends phone detectting your phone so it will reciecve what your sending through blue tooth, otherwise I'm not sure.
Feb 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
