Question about SanDisk Sansa e250 MP3 Player
Doesnt reconize my sansa doesnt connect with my computer and ive tried a different computer and that didnt work. ive also tried holding the record button while turning it on but that also didnt work. i have also tried turing it on locking ut and holding the rewind buttom while plugging it in and it still didnt work.
  • Saroj Mahanta May 11, 2010
    I am unable to store any content from my computer to my Sansa e250 MP3 player. I changed the USB mode to MSC and inserted it in my office computer. When I tried to copy and store from the MP3 player to the computer data is trasferred successfully but vice versa is not possible.Can you please suggest me some way so that I will be able to transfer my selective song from my computer to my music player. Thanks in Advance.
Chad, you need to turn on your sansa and then connect it
Posted on Jul 25, 2008
This is my final cry: My mp3 sansa wont turn on, i made the mistake of dropping it a week ago and it wont turn on. Ive tried the reset the method(15-30secs) but it doesnt work...... at all. it wont turn...
You could try the Updater program and see if you can un-brick the chip. Go to the SanDisk site and download the Updater program, follow all instructions. That is the only thing that might work, as it may have broken an internal circuit.
Apr 04, 2010 | SanDisk Sansa Fuze MP3 Player
I hooked an ethernet cord to my belkin router so i could connect it to my xbox 360 and it dosent work so i connected the cord to my laptop to see if it was the cord. The cord works but it wouldnt connect...
if it says limited connectivity then the port on the router for ethernet is not working
* u need to do hard reset on the router using a paper clip * press the reset till u get a feel of a click * then hold it down for 1 min * then while holding unplug the powercable and plug it back * then release the reset then try with cable connected to computer then if not working * check with different cable if not working try with different computer *still doesnt work then u need to replace the router as the ports on the router not working
Mar 05, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
Sansa clip 2 gig computer doesnt find
This is the method that will force Windows to recognize the Sansa: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa wont turn on/isnt reconized
I will recommend you to get a firmware upgrade for the device...if that doesnt do it, you will need to contact the manufacturer so they have RMA the device,usually update the firmware solve the problems you are having...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e250 freezes!
This should take care of it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e250 MP3 Player
I can turn my sandisk player on but its stuck...
Try this;
Best of Luck.
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
HELP WITH SANSA E260
Try this;
Best of Luck.
"FREZZING UP"
Put the device into recovery mode to see if it will connect that way. Recovery Mode - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. If this works, you should reformat and re-install the firmware. Find it here; http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe If it doesnt work, try a different PC. If that doesnt work, try a new cable. If you need more assistance, please add to the question. Best of Luck.
Sep 28, 2007 | SanDisk Sansa e260 MP3 Player
Frozen screen
recovery mode. slide the hold switxh so that is is redish hold record keep holding record and plug into computer.
Sep 26, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
