Question about EdgeStar Portable Air Conditioner Heater
EdgeStar 400S portable AC
Dose not cool as well as it used to, even after cleaning filter.
  • starfed Jul 25, 2008
    It was purchased approx. May of 2006 but it was only used the first summer in the Tucson AZ area. I put in central heating and AC last year so did not use it. I am now using it in another house in a larger room. I lost the owner's manual so have nothing to reference. What is the max. sq foot it can cool well?
    starfed
  • 19,396 Answers
  • Make sure the air filters are not dirty.
  • Make sure the air inlets and outlets of the indoor and outdoor units are not blocked by objects.
  • Make sure the temperature setting on the remote controller is appropriate.
  • Make sure the doors and windows are closed.
  • Make sure the air flow and direction settings are appropriate.
  • Make sure ventilation fans in the room are not operating.
Posted on Jul 24, 2008
    Brigadier General:
  • 3,614 Answers
How old now the unit..? is it new?
  • micromaster
    micromaster Jul 25, 2008
    check out & download the copy of your manual HERE.
    tHANK YOU...
How many BTU
This is rated at 1070 watts cooling. 1070 Watts cooling is 3650.9915473 BTU/Hr.
3650.9915473 BTU/Hr equals 0.30424929561 in Refrigeration tons....Pleazer Appliance...
Mar 08, 2015 | EdgeStar AP420HS Portable Air Conditioner
Armana APN14K-E portable AC freezes up
Lack of air flow or a lack of refrigerant are the two primary reasons why coils freeze. Clean the filter and the coil, if frost continues it is likely low on refrigerant.
Jun 30, 2017 | Haier Amana Apn14ke-E 14 000 Btu Portable...
NewAir AC-14000E not blowing ice cold air
Unfortunately there can be several reasons for your AC-14000E portable air conditioner not cooling well. As with most portable air conditioners the filter grates on the rear of the unit can be removed for cleaning. When those are removed you may be able to clean some portion of condenser coils. There is also the possibility that your portable AC has a refrigerant leak in the system and will not be able to cool effectively without a repair (which usually costs as much as a new portable AC). Portable AC's are not designed to be recharged and operate on a sealed refrigerant line so even finding someone able to repair it may be a challenge. Your best bet is contacting the company you bought it from and talking through some solutions, they most likely have experience with these units and should be able to help you.
Jul 10, 2012 | NewAir Heating & Cooling
My edgestar portable unit smells like miuldew when running. What can I do to clean it
First, start by cleaning the air intake filter. This alone can make a significant difference. Check the exhaust hose(s) for obstructions. Also make sure that the hose(s) are not drooping to much. As this will trap moisture in the hose(s), rather than exhausting out the window.
Hope this helps you and thanks for choosing FixYa.
Aug 19, 2011 | EdgeStar Portable Air Conditioner ...
My Edgestar AP410HS triggers the circuit breaker in the circuit box outside the house after it's been running a few minutes in air conditioner mode. This is new, it hasn't happened until a few days...
Breaker tripping likely from a loose or bad connection. Wire is getting over heated from not being tight. CAREFULLY INSPECT ALL CONNECTIONS. Including inside the disconnect box outside. Possibly even a bad breaker. HIGH VOLTAGE IS DANGEROUS , if even the slightest bit nervous, call a professional! Good Luck
Mar 29, 2017 | EdgeStar AP410HS Portable Air Conditioner
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Water leaking
You have to open it and clean out the water passages.
Jul 23, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar Portable Air Conditioner Heater Logo
240 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
