Question about Krups Allegro FND112 Espresso Machine
Krups espresso allegro leaking, not making coffee
Water doesn't flow through coffee but spurts clear and drips down side of basket. also water puddle emanating from beneath machine. seemed to work fine whe putting it through it's first rinse. it's putting the coffee in that fvck3d it up. the first coffee trial was done by a professional - someone who'd been a barista.
SOURCE: instructions for Krups Gusto espresso maker
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={F506FE01-D7EC-414A-BEC1-AE53E62990C6}&SelectedProdRef=F880
This is the manual :)
Posted on Jan 25, 2008
Yazz226
  • 497 Answers
SOURCE: leaking Krups XP4030 Espresso Machine
i think it is better if you try contacting ur service centre
Posted on Jun 28, 2008
  • 5 Answers
SOURCE: My xp7240 has also started leaking water from beneath the machine
It seems like a piston sealig is damaged. Not so easy to replace but possible.
Posted on Aug 07, 2009
  • 39 Answers
SOURCE: espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Posted on Dec 29, 2009
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
I have a Krups Nescafe Dulce Gusto coffee maker which spurts a lot of water around the capsule in it but doesn't get any in the cup and only spirts water where can I take it to get it fixed in Calgary
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Nov 19, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
Leaking Krups XP4030 Espresso Machine
Jun 28, 2008 | Krups XP4030 Espresso Machine
The coffee water does not exit from the filter basket. The lever the allows flow into the lid of the carafe when the carafe is in place does lower to allow flow. The blockage appears to be in a valve...
I have the same problem. It's now five months since you asked this question and you've not gotten a response. It doesn't look good for us. I removed that part of the filter basket. Maybe we don't need it. I'm going to try making coffee without it if we don't get an answer today.
Nov 18, 2010 | Krups Aroma Control 229 Coffee Maker
My parents gave me their old espresso machine, it looks gross when I take the top lid off. How do I ensure it is properly cleaned? It's the Krups allegro fnd 112
You can buy coffee pot descaling products at the grocery or department stores, or you can use a vinegar and water solution to break down the mineral deposits. You can use a cloth to start the cleaning, but scrubbing with abrasives is not a good idea.
If you use a retail product, follow instructions; if you use vinegar, use half water, half vinegar. Run it as though you were making expresso, using the frother while you do it. The frother can also be taken apart and soaked. Afterward, run the machine with clean water until all traces of the vinegar are gone. If it is really dirty, you may have to do it several times. Thanks for using fixya.
May 08, 2010 | Krups Allegro FND112 Espresso Machine
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
Clear coffee?
Hello, After many years in the coffee game there are only 3 possible reasons for this, either the water is not heating, this would cause the water to not extract the coffee from the grounds. Or your filter is folding over and the water is running down past the filter....Lastly and the most probable is the spay head is blocked and the water is coming out the over flow if there is one, which is then bypassing the filter. Things to check would be heat, spray head and filter. Hope this helps...Mike
Aug 14, 2009 | Krups XP 1500 Espresso Machine & Coffee...
Need a manual instruction for Krups Allegro Espresso FND1
Go to krupsusa.com and click on "instructions" they have it there
Jun 08, 2009 | Krups Allegro FND111 Espresso & Coffee...
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP4020
The coffee holder is just hanging in place, not secure against the seal as it should be. Make sure the coffee holder is secured flat up against the seal before turning the handle and locking it into place.
Apr 18, 2008 | Krups Allegro FND111 Espresso & Coffee...
Krups Allegro FND112 Espresso Machine Logo
55 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
