Question about Mitsubishi WS-55857 55" Rear Projection Television
TV to PC
In the attempt to connect my PC to my TV I don't get a picture once the computer gets into windows. On boot up it works. I have tried S-video connection and the VGA connect. I did get it to work when I put my computer in Safe mood and in VGA mood. Anyone can you please??
    Problem Solver:
  • 53 Answers
Hello Warlock1434:
It sounds like you will need to change the hertz and the refresh rate for the display setting for the Pc.
Posted on Aug 17, 2008
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
When the computer turns on and I hit the start windows, it goes to an error screen and says to start windows normally or to fix problems. Nothing will start up and I am not sure how to get the computer to...
Either Windows has screwed itself up to the point where it won't boot, or there may be other problems (motherboard, hard drive, virus) that's causing this problem. But it appears that there's a good chance you can still get at the data on your hard drive - I'm assuming you have the hard drive version and not the SSD since you mentioned Windows
I'd take the hard drive out (HP puts its service guide on line, here's the link: http://h10032.www1.hp.com/ctg/Manual/c01683469.pdf ), the restore procedures are also within the guide.
I think these 1000's use 1.8" ZIF drives -- google the drive model # once you have it out, just in case. The easiest way to get it connected to any computer would be to use a external USB enclosure made for 1.8" ZIF drives (try your local stores first, if they ain't got it, then eBay). That's what I"d do with any hard drives that won't boot. You can try and get at the data once it's connected to another computer via USB, and you can run some basic tests on it as well.
Of course ... don't forget to have anti-virus active and running on any computer before you connect a USB drive to it.
Sep 18, 2011 | HP Mini 1000 Netbook
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Install tv tuner card
what kind of tv are you trying to hook to?? K once youve made the physical connection from computer to TV, Even using the Plug & play windows method you need a compatability driver to let the windows computer and the TV talk.
Once communication is establlished pictures, videos, movies,will play from computer to the TV
Jul 09, 2009 | Sony VAIO PCV-V200G PC Desktop
Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Jun 26, 2009 | Envision L19W761 19 in. LCD TV
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Trying to get picture from laptop on tv
first enter in the laptop setup, and find the video option, there you will have something like this:
onboard, extern, both (choose both)
turn off the tv.
boot up windows, right click desktop, properties, choose configuration tab, there wil be two screen, one for monitor the other for tv.
on tv side choose 640x480 (you can try higher resolutions later).
reboot and turn on tv.
worked here.
Dec 09, 2007 | Computers & Internet
No video on boot up!!
have you tried to uninstall the vedio driver and reinstall it then let me know.go to my computer icon right click it > go to properties >hardware tab > device manager and check if there is any yellow mark showing.kindly do this in starting your computer in safe mode.
Oct 09, 2007 | Gateway 500XL PC Desktop
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
