Question about Juicers
What type of grease
I have an antique juice that my husband has updated and i need to know what type of grease goes into to upper mechanism
I think its wrong that you want me to pay 10.00 to find out what type of grease to use in my antique juicer
Posted on Jul 25, 2008
How do I make apple juice?
there are plenty of recipies on the net that will help you make a decent apple juice
go google and type in--how to make apple juice
Oct 11, 2015 | Juiceman Juicers
Manual for Emson Juice Extractor, Model GH-2011
I bought one without a manual today for 2 dollars at a yard sale , blades lock in about a half inch - turn counter clockwise to remove, may need to press down or press button in back. base below comes off too for cleaning - turn clockwise. They may come off hard the first time. the button in the back may help releasing both. Make sure to unplug first. I don't have a manual either, just some mechanical sense.
Oct 07, 2014 | Juicers
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
May 20, 2014 | Salton JM411 Juiceman II Elite Juicer
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
The juice screen has become blocked with "veggies"
You can brush it with a new tooth brush, or soak it in vinegar for a couple of hours.
After getting rid of the old residue, you need to rinse it off right after juicing the next times.
Best types of juicers
Apr 01, 2011 | Breville 800JEXL Juicer
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
I HAVE AN OLDER KRUPS JUICER TYPE 251. IT SAYS IT IS MADE IN SWITZERLAND. THE METAL HANDLE WHICH KEEPS THE TOP ON TIGHT IS LOOSE. THE SPRING HAS FALLEN INTO THE BOTTOM OF THE HOUSING. THIS MEANS IT CANNOT...
Did you ever find a manual? I have the same machine, working fine but I'd like to know if I should use the plastic strainer for all my juicing or just for certain fruits or vegetables.
Jul 18, 2010 | Krups Juice Extractor
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Juicer does not work.
Had same problem...juicer stop working without any warning. First I took the unit apart and remove the on-off switch and capacitor and had them tested by appliance shop. Both checked good. Next I remove the small circuit board behind the face plate below the motor shaft; circuit board was coated with oil and shaft grease. Appliance shop did not know how to test it, so I clean it all up and reassemble the unit. I told God is it worked I would praise Him. Hallelujah to God ... it worked. I hope my experience helps someone. God is good.
Jul 18, 2008 | Champion 2000+ Household Juice Extractor
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
Juicers Logo
46 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
