Question about Insignia Audio Players & Recorders
When I turn the unit on it lights up shows me the raido station gives me a brief second of noise then the unit shuts down
I got thinking about how the unit kept shutting down when I turned the voloum up and thought the problem may be in the speaker connection, more voloum, more power.
I had my speaker wires attached to the edge of the wall and ceiling with small nails. I thought, what what if they were hitting some wire? could that cause a grounding effect?
I rewired the speaker system and now I am rock'n out once again.
If you folks encounter this problem, of the unit shuting down when it is turned up, you may want to ask them how they have the speakerwire mounted?
Just let them know they may grounding out the system with any kind of metal or steel touching the wires,and it will shut down when turned up.
And if you want to you can tell them to thank Luke A. Zoid.
Posted on Jul 26, 2008
Unit on but then iys shutting down
Can you please more setails in to what your unit is doing. Does the main start up screen come on then the tv turns off? Does it make a clicking noise? Does this happen every time you try to turn your unit on?
Jul 24, 2013 | Televison & Video
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
When i switch tv on, it shows picture for 5 seconds then goes into standby. the tv is a vistron ltm-3271e lcd
The problem is associated with the power supply that cannot run under load. The showing of picture for a brief period of time indicates that the main board, ballast, inverter and panel drive are all OK. The unit turns on but the power supply cannot sustain the power requirement of the unit and shuts down.
The usual culprit on the power supply are blown or bad capacitors. Check the power supply for such capacitors. If no apparent damage or defect is found, replace the power supply.
Nov 07, 2009 | Televison & Video
2001 Acura 3.5 RL Radio Problem Stopped Working - Inoperable
need raido code for 01 acura, anyone got it?
Apr 30, 2009 | 2001 Acura 3.5RL
Flashing red light
Go to you www.youtube.com and you may be able to find helpful videos on this. But if you bought it new it is under warranty and they will fix it. You just pay for shipping.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
May 13, 2008 | Samsung HT-X40 System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
RCA Wireless headphone triggers off after 35 seconds of operation
ya the volume of your source is your issue.
if it is too low, the unit cuts out after 45 seconds or so...
crank up the volume and turn it down on your headset
Mar 16, 2008 | RCA WHP140 Consumer Headphones
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
101 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
