WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS GOT FIRE POWER AND SPARK SO NOW WHAT ITS DRIVE ME CRAZY WHAT TO DO. WE CHECK THE SPARK PLUG AND BATTERY AND ITS GOT GAS BUT IT WONT START WHAT DO U THINK IT IS
Did this happen all of the sudden? Or was maintenance performed on it recently and now it won't start? What size engine is this? V6, 305 V8 , or 350 V8Did this happen all of the sudden? Or was maintenance performed on it recently and now it won't start? What size engine is this? V6, 305 V8 , or 350 V8
You can't post conmments that contain an email address.
Re: WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS...
92 Camaro, V8 5.7 multi port, new pump, good preasure. runs when primed, wont start without prime. After sitting a few minutes, engine fires wont start. How to check EGR Valve and what does it do?
Ok I know what a EGR Valve is, but is it causing my Problem? It seems that the injectors are not working. How do I check the injector signal or output of fuel?Ok I know what a EGR Valve is, but is it causing my Problem?
If you Camaro has an electronic chip in you stared key , that I think is the problem , you need to take your car with your mechanic and take a part , at the end the steering column is a small Bering they need to change that Bering, the job is price to fix was $750.00, that's is the problem, happen to me and my mechanic change that Bering plus give me a new keys,. That little Bering is the one thing make the spark for the entire car can star. , he check my starter was right and after little willie he found it. The solution. I have same Camaro 92 V8 automatic.
i hope this information help you.
Remove the battery cables and inspect them for corrosion build up. Clean with baking soda and warm water. Reinstall and try to start. Also check carging system. 13.5-14.5 volts when running.
