Question about Sony Handycam DCR-TRV520 Digital Camcorder
Dcr-trv520 error code C:31:23
Own a dcr-trv520 ntsc and it began to chew up tapes and cis giving me a C:31:23 error code please help.
  • Anonymous Aug 17, 2008
    same issue on Sony PD 170 a semi pro camera. I took it in for repair some mmonths back and tried it today and error code came up! Camera has had little use from new and is basically useless and costs me an arm and a leg!
For those that said to reset your camera, thanks.
DCR-trv520 handycam. Left power on, took out battery. Waited a minute.
Put battery back in. Worked liked before.
Thanks.
Posted on Jan 02, 2012
  • Eugeno Brussell Jan 02, 2012
    My error code was C:31:22 and now my tapes play fine.
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
SOURCE: Video camera displaying Error code C:31:23
solved the problem very easy in 5 seconds... by removing all batteries .. then shake the camera very hard (or alternatively hit the bottom hard with your hand -at your own risk-) .. now the memory can't hold that there is an error and with the hitting things get better: got it from: Re: Re: Re: Self Diagnosis C:31:22 Jim - 16th Jan 2005 9:33 When you whack the camera (I don't advise it) you are probably loosening the debris or condensation enough to get the camera going. The reason for the battery removal is to reset the camera so old error codes are wiped and to get them again the problem must recur. If you take the batteries out and put them back in with positive results the movement involved in doing this probably serves as well as whacking it (sometimes just turning it over a few times will work). I have in fact seen with my very eyes, repair people (independent not at Sony) take a camera in, wait until the customer was out the door, take the main battery off, whack the camera VERY HARD and turn it back on. This has worked so many times I am embarrassed to mention it. They then put the camera on the shelf for a couple of days and call the customer back and charge them for a complete (and expensive) cleaning. The camera was usually fixed before they got to the car. I would offer you some simple advice (from experience and observation) that you may take or not at your own risk. Understand that anything you do in an attempt to fix your own camera may result in complete failure and irrepairable damage to your camera, including anything I mention here. Just be forewarned
Posted on Feb 03, 2007
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Had the same error message on my TRV-720, and could not come up with a solution for weeks until I found this website:
http://www.protechcam.com/wwwboard/messages/127.html
Now the fix you will not believe, nor did I at first, but requires you to power off the unit completely and "Smack it" a few times fairly hard.
Now you may do this at your risk, but I swear it fixed mine and all the other people listed at the above web site.
I thought it was a joke - but it works!!
Good Luck!
Posted on Jul 28, 2008
SOURCE: C:31:23 Flashing and viewfinder says "Reinsert the casette"
i know what setmaz says sounds kind of ridiculous; but i got desperate and tried it myself... i can say that as far as i go its a proven method and the camera will start working
Posted on May 14, 2009
Tape stuck, Mechanically Eject
Try staring up the camera while hitting the rewind button
Oct 29, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
When I attempt to insert the mini tape into my Sony Handycam dcr-hc21 ntsc, it doesn't load the tape in all the way and an error message reads that it was loaded incorrectly and to please re-load...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 20, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Tape malfunction for Sony TRV520 is not bad tape definitely the camera
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Oct 04, 2010 | Sony Handycam DCR-TRV520 Digital Camcorder
I have a Sony DCR-TRV520 NTSC HandyCam... When I turn it on to record (and take the lens cap off) I am not getting a picture either through the view finder or on the LCD screen. Everything else seems to...
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Aug 28, 2010 | Sony Handycam DCR-TRV520 Digital Camcorder
Video camera will not playback tape smoothly - jumps along
Please get into town, and buy the 8mm Camera cleaning tape from W.H. Smiths, Currys, Comet, Maplins, put that in your camera on record mode for 20 seconds and then remove it, and carry on filming, it is just dirty heads you have got, take care.
from
David
May 25, 2010 | Sony Handycam DCR-TRV520 Digital Camcorder
Parts referencer for DCR-TRV520 Digital Camera
It appears that part is not available. I've checked many places and many ways. 1-803-855-51 is a part number. Eric
Jun 20, 2009 | Sony Handycam DCR-TRV520 Digital Camcorder
Sony DCR-TRV260 NTSC
When video heads got dirty / clogged, camera gives this error.
Use good quality Video Head Cleaning tape to clean heads.
Dec 19, 2008 | Cameras
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Tape Cleaning on-screen warning
Depending on the age of the camera/cassette, it may be that the heads are not just dirty, but are actually worn down. The gray bars are the DV equivalent of snow - data has been lost or at least cannot be displayed. If cleaning doesn't solve the problem, the heads probably need replacing. Depending on the age of the camera, it may be more cost effective to upgrade to a new camera.
Apr 02, 2006 | Sony Handycam DCR-TRV520 Digital Camcorder
Sony Handycam DCR-TRV520 Digital Camcorder Logo
330 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
