Back to:
Tags:
Garmin StreetPilot C330  GPS Receiver
Garmin StreetPilot C330 GPS Battery
posted by jlmaxie1 on Jul 24, 2008
I purchased brand new Garmin StreetPilot C330 GPS in September 2007. I feel I need a new battery as it does not hold the charge too long. Can you please advice me what kind of battery I need , where will I find it and what's teh model number of the battery it uses. I also need step by step directions how to replace it. Thanks ! Will not poower up. Will come on for a couple of seconds and then powers off. I have tried reset and it does not work.
What are my options to resolve this. I got the C330 for Christmas 2007
thanks
Jerry
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2008
Not Rated (0)
fidoliedo
Rank:Guru Guru
Rating: 89%, 57 votes
Remove front bezel by lifting just under the GARMIN name. Remove the 4 outer screws. Gently pull apart. Keep in mind the orientation of the antenna as it's a bit tricky to put back. The battery is mounted between the two speakers.
It's a round cylinder item attached to the main board by a plug. Problem is this plug also houses the connection to the speakers. If you are good at rewiring, cut the battery leads and reconnect them to the new battery. Not sure where to get the battery though.
When putting back the antenna, keep note of the tabs. The lower one remains on the outside of the shelf guide, and the upper one is on the inside of the shelf guide.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Garmin StreetPilot C330 GPS Battery:
I don't want to Accept this solution
Can you Help with these GPS Devices problems?
Garmin StreetPilot C330 (010-00401-10) GPS...
Hello, I had a problem wiht my Notebook which required a...
streetpilot c330 11months old rarely used stored inside...
the unit simply wont turn on. I;ve checked voltage with a...
My 330 wont power on
c330 wont run on battery, Works ok when plugged in to 12...
Loading problems.
Repair Service
Find GPS Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
