Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi big screen vs45605
My big screen tv won't come on, it just blinks the green light a few times and doesn't come on. what do i need to do?
  • 4 more comments
  • carolinedrtr Jul 24, 2008
    after i did it, it didnt do anything so i hit the power one more time and now it is one solid blink then 2 quick what? and thank you for responding
    that would be great. Last time i looked for a manual they said they didnt go back that far. thank you so much.
  • carolinedrtr Jul 25, 2008
    It is the same even though the numbers dont match?
    thank you for clearing that up for me,,,,,,,,my kids say thank you too. I will go and print this off and i will have my husband take a look...thanks again
  • tlmcguire73 Sep 02, 2008
    When I tried the input and menu button I got a code 23. So what dows this mean?
  • sherry652 Dec 14, 2008
    I have the same problem. WHen I hit the power the green light turns on for a few seconds and goes off and the tv doesn't turn on.
    When I held down the menu and input button for 5 second, the green light blinked twice then three times.
    Any idea what may be wrong?
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Posted on Mar 21, 2011
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
We have a Mitsubishi Big screen projection tv model no. VS-50705. when the on button is pushed it clicks like it wants to turn on but then doesnt. When I unplug and plug back in the green light flashes...
This could be a trouble code for your model television. Try counting the blinks and note any pauses in blinking. It could be a one or two digit trouble code. Then once you have that number, type in your tv model along with the words "trouble codes" or "diagnostics codes" or "green light blinking" and see what you get. Hope this helps...
Jan 08, 2010 | Mitsubishi WS-65712 65" Rear Projection...
MITSUBISHI WS-73909 will not turn on 1. I have a Mitsubishi Big screen TV model no WS-73909. Few days a go the city power went out when the TV was off. The TV had a surge protector. Then the TV will not go...
Are you a Quailified Technician ? Because this repair is not for the novice. The best thing I can tell you is contact a Mitsubishi Authorized repair center or tell me what area you live in and I can find one for you. cost is 250-350 to repair.
Apr 10, 2009 | Mitsubishi WD-65000 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
410 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
