Question about SanDisk Sansa View 8GB MP3 Player - Black
I can open file that i added in windows
Ok i add songs and videos in my windows xp computer but wen i try to open the folder of the sansa in a mac it shows nothing how can i see them plz answer
Well, you rproblem lies with the built in DRm feature
this blocks you from putting all your music on your Sansa, and then going to your buddies house and giving him all your music from off your iPod.
its there, it just wont show it
Posted on Dec 28, 2008
I can not resync my sansa e270 when i plug it into the computer, i use rhapsody and never had this problem before
Hi, theres 2 ways usually to sync with sansa.
usually wen u plug it into the usb cord, u shud be able to open a folder and put musik through that.
My computers. than go to Sansa
or WMP depending on ur version
go to Synchronizing or Copy to CD or DEVICE.
there should be syncing button under the music list depending on the version.
but i stick to open my computer and the Sansa folder.
IF NOT THAN DO THIS..
Go to ur Sansa in the USB option change it to MSC than follow these instructions
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the drive for your Sansa.
3. click on Tools choose File Option, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
Good luck.
Mar 12, 2011 | SanDisk Sansa e270 MP3 Player
There are several songs that are on the m240 that are not showing when you look at it's files - how are these hidden?
If you added songs to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP:
1. Double-click My Computer.
2. Under the Tools menu, select Folder options, then click the View tab.
3. Under Hidden files and folders option, select Show hidden files and folders.
4. Uncheck the Hide protected operating system files (Recommended) check box.
5. Click Apply, then click OK.
Windows Vista:
1. Double-click Computer.
2. Click the Organize button on the upper left corner.
3. Click Folder and search options.
4. Click the View tab and select Show hidden files and folders.
5. Uncheck the Hide protected operating system files check box.
6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode
1. On your Sansa player, switch the USB mode to MSC.
2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk
1. Locate the Sansa player under My Computer.
2. Right-click the removable drive associated with the Sansa player, and select Properties.
3. Click the Tools tab, and then click Check now.
4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes.
5. Click Start.
See also this tip on what it all means http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
Sansa m250 2GB can not see any files or play
I had a similar problem.
This is how I fixed Sansa m250 2GB
I have Windows XP, so if you have a different version of Windows you might have to do something else.
Connect the player to your computer.
From My Computer open the drive that says SANSA M250
If there is no folder called "audio" make a folder named that. (this is where your future mp3 files will be stored).
My audio folder was missing, so I had to do this.
Now go back to My Computer right click on the SANSA M250 drive scroll down the menu and open the folder that says "Open As Portable Media Device".
Now click on the icon that says "SANSA M250"
Now open the folder that says "FOUND.000".
If you are having the same problem that I did all your old mp3 files will show up with a file extension .CHK instead of mp3 and the names will be numbers. You can either erase all these & reload all your songs into the "audio" folder I mentioned previously or you can rename each file extension to a .MP3 instead of .CHK. (after you change them to .MP3 they will load on your mp3 player. But, remember if you do choose to rename them instead of erasing and reloading, when you want to permanently delete them you will have to access the "FOUND.000" folder again to do that.
Dec 07, 2008 | SanDisk Sansa m250 MP3 Player
Adding songs to go list
learn how to use windows explorer and transfer them to the music folder
Jul 13, 2008 | SanDisk Sansa e250 MP3 Player
Sync problems ...
The instructions with pictures are on pp. 13-19 of the user's manual:
Loading Music
You can transfer music from your computer to the Sansa player using the dragand-
drop method or using music managing software like Windows Media Player.
Drag and Drop
Follow these steps to drag-and-drop music to your Sansa e200 player:
1. Connect your Sansa e200 player to your computer.
2. Select Open device to view files using Windows Explorer on
initial connection.
3. Double-click on Sansa device.
4. Double-click on the MUSIC folder.
5. Drag and drop music files from your computer to My
Computer\Sansa e200\...\MUSIC.
Before you can create playlist and transfer (or synchronize) them to your
Sansa player, you need to show Windows Media Player where your songs are
located.
Adding Music Files to Library…
1. To add music files to WMP 11’s library, please follow these steps:
2. Click the arrow below the Library tab.
Loading Content 14
3. Make sure Music is selected then click Add to Library…
4. In the Add to Library dialog box, click one of the following options
then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your
personal Music, Pictures, and Videos folders, as well as any files
stored in the public Music, Pictures, and Video folders that everyone
who uses your computer has access to.
- My folders and those of others that I can access:
personal Music, Pictures, and Videos folders, the files stored in the
public Music, Pictures, and Video folders, as well as the files stored
Loading Content 15
in the personal Music, Pictures, and Videos folders that belong to
other users on your computer.
Mar 12, 2008 | SanDisk Sansa e250 MP3 Player
Delete songs
The MUSIC folder is a "hidden" folder when in MSC mode.
To view it (assuming you're using Windows XP) go to:
My Computer>Tools>Folder Options>View Tab.
Scroll down till you see Hidden Files and Folders
and click on Show Hidden Files and Folders, and then OK.
You should then be able to see all the folders on your Sansa. The "hidden" folders will appear slghtly lighter in color. This is where you can delete click on folder then go toleft of screen to "delete this folder" (or open folder and click individual song" then go to left of screen
Mar 08, 2008 | SanDisk Sansa e260 MP3 Player
Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Feb 10, 2008 | SanDisk Sansa E280 MP3 Player
Delete
Actually you cannot delete them from your mp3. you gotta connect it via usb to your pc, go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
P.S.Please rate accordingly...
Thank You
Computerrep
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
How do i delete pics from my sandisc sansa e260.
what you need to do is this. i cant help you if you have a mac but i can help you if you have a pc. for pcs, you need to plug in your player.once its connected, double click "my computer".in it, the player should have registered and their should be an icon that says "sandisk sansa e260" ( or something like that, i couldnt exsactly tell you considering my player is completely busted at the moment.)then you should see a bunch of files.the files will include album art,songs,and folders for videos or pictures.in the pictures folder you can access your pictures,and right click on the files you wish to delte, and simply just...hit delete.
Oct 08, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
