Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Is there a relay switch someplace for washer
After a severe thunderstorm the other night which took out our transformer my washer doesn't work, won't even fill, there is water coming to it. the dryer works but not the washer. don't know if it is connected to the storm or not but it worked fine that day. my husband took the control switch for the washer to have it tested and they said that part hardly ever goes so what now? could there be a relay someplace to try?
  • stombari Aug 05, 2008
    Since you think that is the problem I just won't have the money to fix it for quite awhile, but thank you for your advice, I appreciate it. I thought it would be a quick fix like a relay switch.
  • 706 Answers
I'll take a stab at helping you.. If what you said is true in regards to a thuinderstorm, you may have experienced a surge in your power lines that found its way into you control electronics for your washer. Most , if not all of the controls these days are low level voltage components similar to a radio or tv and are sensitive to surges of this kind. The washer may have 'taken a hit' when the transformer failed. The dryer may have also been exposed to the same surge and survived it.Even if they are both plugged into the same power receptacle, there is no guarantee that they would both get damaged or both survive but from your short description of pre and post thunderstorm, there is a good chance your washer controller took a hit. Typically, the control board will activate a solenoid /relay to open a valve and let water into the drum.. but if that board is damaged then that won't operate correctly. Hope that helps...
Posted on Jul 25, 2008
  • Rick Gelin
    Rick Gelin Aug 06, 2008
    Please understand that my comments were based on the information you provided and I am merely speculating on what could have happened. The emphasis is "COULD" have happened. It may be more than coincidence that the washer failed to operate after the power line transformer was damaged by a storm. Having said that, it is possible that the water inlet valve is the failed component anyway. There isn't much to it ( an electrically operated valve containing a coil that when energized, causes the valve to open, allowing water to flow into the washer).. That coil may have been damaged by a voltage spike or surge.
    If possible, can your husband disconnect the water line and remove that water inlet valve from the washer? He may be able to have that part checked and if it is defective, simply replace it. It may be an inexpensive repair afterall. Hope that helps...
Low bean won't come on, on a 1998 chevy truck. fuse all good, don't know if it has one of those round limer switch or not - help
Check dimmer switch, replace if needed,'
Check light sockets and wires, replace as needed.
Check for relay if applicable.
Jan 21, 2013 | Chevrolet Cars & Trucks
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
2006 Chevy Cobalt wont start. It doesnt turn over. All i can hear when i try to start it is a rapid clicking sord of sound. Any ideas!?
This means your battery is dead. Whether it's from a catastrophic failure of the battery, or something ran it down is to be determined later, but for now you should be able to jump start it to get it where you need to go. Be prepared for it to not start again once you shut it off, so make sure you're someplace you can get a jumpstart, or fix the car. If you charge the battery, or jump it and run it for a while, if it doesn't start again, you have a bad battery. If the alternator is bad, you'll get a big failure of the gauges and lights, and it will quit running altogether. If you're nearing about 60,000 miles, your alternator is running out of time anyways, so be prepared for that one.
Jul 25, 2010 | 2006 Chevrolet Cobalt
Magic Chef refrigerator makes high-pitched whining
well u need to get it check by any expert throughly u need physical assistance u have done much.
Jul 25, 2009 | Magic Chef CTB1821AR Top Freezer...
Intermitent start
Bad/malfunctioning relay. Let me know if you want to work on this.
Jun 01, 2009 | 1995 Mercury Villager
NAD AV713 receiver won't power up
I had the same problem with mine AV713 it turns out to be the relais of the power unit (left site above the transformer). solution may be to replace it with http://ecb.omron.com.sg/pdf/relay/power/G5PA-1.pdf e.g. good luck TB
Nov 20, 2007 | Sony A/V Receiver
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
209 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
