Question about Maytag Washing Machines
SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
  • taznotadevil Mar 14, 2009
    The black mold around the gasket area of the door is pretty bad. I think the gasket may have to be replaced. Will Maytag do it for free??? Do they have another fix that they will perform for free??
  • 706 Answers
If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
Posted on Jul 25, 2008
Tip
Does your front load washer smell bad?
In order to keep all front loader washers from smelling and developing black mold make sure you leave the door open when not in use. If it is allowed to dry out between washings the smell and the mold will be squelched. You can also leave the dispenser door open also to dry out.
on Mar 12, 2012 | Whirlpool Washing Machines
How do you get rid of mold smell in washing machine
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Washing Machines
Where is the filter on the series 70 washer? my washer has a stinky smell and someone suggested it may be a filter that needs to be cleaned.
clean the door boot carefully with bleach if mold grows in the lower door drain holes it will mold and stink,you will see black spots on the boot,thats mold
Sep 11, 2011 | Kenmore 24032\24036 Top Load Washer
I have a maytag washer model # mah5500bww serial # a2907048cc that came with a house i just bought . The rubber ring just inside the door has black looking mold on it and sounds like water is in the tub...
Hi - the water is normal - bellows are water filled. the molds well not much one can do about that now - it has etched into the rubber - try clean it but will not go away - use more hot/warm cycles to keeep it under control or replace it.
cheers
Jul 09, 2011 | Maytag Washing Machines
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Why does our duet whirlpol washer smell like mold. Our washer are
Your washer smells moldy because there is mold growing in it somewhere. To kill the mold and clean the inside of your washer do a hot water wash using no clothes but adding two cups of bleach to the machine. It will also smell better then.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
881 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
