Question about Kenmore 73952 Gas Dryer
Excess dryer lint
The exhaust from the gas dryer is located on the wall of the house right next to the swimming pool pump . A build up of lint on the pump vents caused the pump to burn out . How do I trap the extra dryer lint, on the exterior to prevent it from reaching the pumps?
Model 74872401
  • 5,911 Answers
It is strongly recommended that you DON'T trap the lint. Doing so, can cause the lint to back up inside the ducting and eventually cause longer dry times on your clothing, and/or your heating circuits to over heat and fail. A dryer requires proper (unobstructed) air flow in order to work efficiently. I would recommend that you reroute your dryer ducting to divert the exhaust away from your pool pump. Please let me know if you require further assistance.
Posted on Jul 25, 2008
Takes about 4 hours to dry any load. Have tried different settings. Husband cleaned lint traps, hoses, etc. Gas turns on and shuts off about every couple of minutes. Any ideasa?
Most likely problem is the exhaust is plugged. Lint build up and eventually restricted the humid exhaust air.
To test for this locate the exhaust vent where it exits the house. With the dryer running feel for the air flow. It should be similar to the flow you feel from hair dryer.
Second test is to light load the dryer setting the heat to high and after several minutes of operation open the door and confirm the clothes are hot to the touch.
Hot clothes and no air flow for ever to dry!!
  1. Remove hose from wall connection. Confirm vent hose not plugged by running dryer. Very dusty process. If no air step 2.
  2. Remove vent hose from back of dryer. Confirm air flow from dryer. Very dusty process. No air step 3.
  3. Service dryer blower likely plugged with lint. If dryer basket turns I would assume blower is also turning connected by drive belt. The blockage internal to dryer.
  4. So if not 1,2 or 3 than blocked vent hose to the outside . Suggest using a vacuum hose to carefully try to retrieve lint build up. Lets hope that it is not a roof vent because it would really suck trying to pull the blockage out. And unless your Santa roof tops are dangerous places to play.
  5. Well at least at this point we know why the clothes are not getting dry. What ever you do do not breach the venting in the walls. Moisture will build up along with the lint and create havic with mold!!!
  6. Call your husband
26044146-iw0uppkrtuaby0cw3enjxd1j-2-5.jpg Not to sure about the leaf blower, Might work?
Dryer Vent Cleaning Quick Easy Trick
Jan 08, 2016 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heat is intermittent
It is probably clogged in the exhaust where the lint tube connects to your wall/house. Inside the wall can get very clogged with humidity and lint creating a goo that blocks the air from escaping.
Disconnect the dryer from the wall, put on some rubber gloves and reacg up into the wall and you can pull out globs of old wet lint, coins, and other junk trapped in there. Secondly, check on the outside of your house where the exhaust is released and make sure it's not clogged there too.
Mar 26, 2012 | Whirlpool Dryers
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
The back of the dryer is red hot and smells like burning plastic when it runs
Don't use it until you fully check it out!!! If you are comfortable... unplug it and check for excess build up of lint in all parts Fan, element housing, exhaust outlet, and finally the hose and outside vent flap. If no excess amounts of lint than your element may have a "bad spot" and be shorting, which necessitates the element replacement. Good Luck!
Douglas
Jan 28, 2011 | Dryers
Hello, I've got a Kenmore 80 series dryer Model: 110. 96584110 that is tumbling but not heating. What would you recommend as a next step short of buying a new dryer. Should I change the heating element and...
Check for lint clogging first. Pull the unit away from the wall and look to see if there is an excessive build up of lint at or near the discharge vent or into the vent line. Clean as needed. If it's really clogged you may have to remove the back cover.
If no joy, then check for a bad thermostat. There should be two. They are located on the discharge vent near the dryer exhaust blower. You will have to remove the back cover of the dryer to get to them. Check the stats for continuity. MAKE SURE the power is off before working on the dryer.
It's much more likely to be on of the two items listed above, but if the dryer isn't clogged and the stats are both good, check the heating element.
Aug 20, 2010 | Kenmore 63942 Dryer
Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 07, 2009 | Dryers
The lint screen does not capture lint. The lint
To dispell a common myth. There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust. However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. It is strongly recommended to have the exhaust vent hose checked and/or cleaned a couple of times a year to ensure it remains obstruction free.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not becoe clogged.
If you have any questions, pleae let me know. I hope you find this information helpful.
Aug 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Maytag Gas Dryer # LDG9606AAE, No Heat
There is a thermal fuse located on the back of the blower housing. Part # 306604.
Jul 26, 2009 | Whirlpool GEW9250 Electric Dryer
Burner not stayinyg lit
since burner is igniting, it probably is OK. next check is limit switch. this switch shuts the gas off if it senses excessive heat (blocked vent ... usually caused by lint) limit switches themselves MAY go bad ... bu rarely PS check to make sure the vent is blowing exhaust to outside of house (i've seen birdnests in the exhaust port cause your problem)
Apr 27, 2009 | Dryers
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
