Question about Roper RAS6233KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
All I get on any setting is a humming sound and nothing else. The washer stopped once it filled with water and just gave the humming sound. I drained the water and am not searching this site for an answer.
  • 2 more comments
  • smmcinto Jul 26, 2008
    This happen to anyone else?? I have searched every site possible looking for an answer and got nothing.
    FIXED IT........I took up the cover on top.....unplugged the lid switch plug to reset it, plugged it in, and it works great.
    ok....nevermind.....too good to be true
    now it works perfectly until halfway through rinsing it stops completely. So pretty much I think it just won't spin, it did everything else right up until that point. I can hear the click when I close the lid so I am not sure if it is that. I unplugged the timer and reset it again, and still get nothing.
    HELP PLEASE, since after I drained it manually last night to try and fix it, thought I fixed it let it run, and now full of water again.!!!
  • Anonymous Oct 29, 2008
    Same EXACT issue...
Yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Posted on Nov 02, 2008
I have a washing machine that when the washer drains and the rinse starts it stops and makes a humming sound and does nothing
What kind of washer is it? Some of them will do that until so much water has been drained out of it then it will spin. If you would like to know a definitive answer on your washer then I will need the make and model. It is usually located behind the door or under the lid.
Jan 17, 2017 | Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Front load washer stopped working
What is the model number listed on the washer?
Oct 13, 2012 | Washing Machines
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
A humming sound in the cycle knob
Make sure that the room is quiet then check that there is a clicking noise from the lid when it is nearly closed
If not then the microswitch is out of whack and needs adjusting
When you slam the door down it is probably enough to make the switch but then the machines movement will undo that action
Jun 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Samsung Silvercare hums, but does not run
FIXED!!!! amen. Attached to the back of the washer was a plastic bag with a tech spec pamphlet. Inside the pamphlet were instructions for running tests via the front control panel on the various cycles to weed out the problem -- fill, spin, drain, etc. The test failed on the draining section citing a problem with the drain pump. So long story short and MANY towels later, I found a small finishing nail in the motor. I had removed the hoses thinking there might be a blockage, but found nothing. So I removed the motor and washed it out. Nothing odd there. So I took the front off the motor and found the nail. It somehow made it through the drain holes in the washer drum but got stuck in the motor.  Thank you Samsung for taping the tech manual to the back of the washer. I could not find it anywhere on the web for this model. After discovering the testing available via the contol panel and the simplicity of the machine, I love Samsung.
Apr 01, 2008 | Washing Machines
Roper RAS6233KQ Top Load Washer Logo
401 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
