Question about Toshiba 50H82 50" Rear Projection Television
Red lines Ive got a Toshiba 50H82 rear projection. It is displaying red horizontal lines on the screen? Any solutions or input out there? Thanks
  • 59 Answers
If you go to a n unused input ie ( video1) and the lines are there , it is a bias problem with the red pix tube. either the tube is bad or the sceen adjustment is up too high.
Posted on Jul 24, 2008
57H81 rear-projection Toshiba red un-aligned
sounds like to me that you need to replace the convergence IC's.
Apr 06, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Distored picture
Well, if your horizontal is off frequency and you have diagonal lines then there's no need to look at the Horiz Output Transistor or the Vertical section. You will have to use your scope to check the oscillator freq. and go from there.
Jan 14, 2010 | Toshiba 50H82 50" Rear Projection...
RED HORIZONTAL CONVERGENCE OUT.INSTALLED NEW STK 392 110.SAME PROBLEM
Please check does STK IC getting +22 and -22 volts supply to work properly, check pico fuses that might blew off / open, replace it and check.
Thanks.
Oct 29, 2009 | Toshiba 50H82 50" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Convergence problem
my convergence are having a problem the blue color won't moved
Oct 03, 2008 | Toshiba 50H82 50" Rear Projection...
No video on a 50H82 Toshiba Projection
If the screen is lit, then there is high voltage. If there is no video, and the screen is lit, then there is a loss of video. The fault can be anywhere along the main video path before it gets decoded in to the red, blue, and green compositions.
If the screen is not lit, most likely there is a high voltage failure, or there is a failure in the bias supply for the tubes.
When there is a loss of high voltage, this can be from any of the components in the high voltage area. Some of the main things that go defective are the flyback, high voltage multiplier, and various other small components.
Have you considered to replace the set with a good Plama or LCD set? This repair may end up being on the expensive side.
Jerry G.
Mar 10, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Red gun gone...
STK392-110T X 2 in TOSHIBA , Do not use generics.If you
want to upgrade = STK394-160E = I use Hitachi brand......T.
Oct 29, 2007 | Toshiba 50H82 50" Rear Projection...
Color is Bland--Seems we're missing red color
THE PROBLEM IS THE SAME AS I HAD PREVIOUS,A PROJECTOR BULB HAS GONE ON THE RED PROJECTOR,YOU PROBABLY HAVE YOUR SOLLUTION BY NOW I HOPE SO ANYWAY.
Feb 24, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
