Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
UNIDEN DWX207 SERIES ITS WATERPROOF
ON THE BUTTOM OF THE PHONE IT HAS A STICKER THAT SAYS PRESS HERE TO ACTIVATE THE PHONE I DID BUT NOTHING HAPPENED I RETURNED IT AND GOT ANOTHER ONE SAME THING ALL IT SAYS ON THE HANDSET IS WELCOME PLEASE WAIT! IM I NOT DOING RIGHT
  • 1818 Jul 28, 2008
    I HAD TO CALL CUSTOMER SERVICES TO FIND THAT OUT THANKS VERY MUCH
  • Anonymous Aug 19, 2008
    Same problem. I am going to try the "ballpoint pen" solution tonight.
Same thing was happening to my phone...Welcome! Please wait... After at least 40 hours of charging I was getting a little fed up. I picked up the handset, took a ball point pen and pushed the "activation" area on the bottom the phone...heard a click...now it is working. I don't think the tiny pin that comes with the phone activates the phone properly.
Posted on Jul 27, 2008
    New Friend:
WHERE at the bottom of the phone??? I see no little hole at all.
Posted on Nov 21, 2012
Same problem here! Costco said bring it back, I tried the pen after reading this and BAM! It worked instantly
Posted on Sep 07, 2008
  • koz1 Sep 07, 2008
    Same problem - Costco says return phone. Used pen and it worked instantly
  • jeanjoone
    jeanjoone Nov 21, 2012
    WHERE on the bottom of the phone? I see no little hole at all?
I had the same Welcome! Please wait. . . for 3 or 4 days.
The ball point pen solution worked right away! ! !
Thanks.
Posted on Aug 20, 2008
Thank you for posting this, I was having the same problem and the pen worked. You need to write to Uniden and ask for a reward, if they don't note that in their phones they are going to get a bunch of these returned.
Posted on Jul 29, 2008
Same problem here too. Costco say's "bring it back"
Posted on Jul 25, 2008
How can i get my dwx207 to comunicate with a phone line
that is an extension phone only will not work without the control unit e;i answering machine that plugs into phone jack on wall
Apr 12, 2015 | Uniden Dwx207 Dect 6.0 Waterproof...
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
Uniden registering
Follow the registration instructions beginning on page 5 of the DWX207 manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DWX207om.pdf
May 15, 2013 | Uniden Cordless Phone
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden waterproof phone does not charge.
Make sure charging indicator showing charge, if so! the battery will need to be replaced, try and get the genuine replacement because there have been problems reported with aftermarket batteries not working in the phones due to the specifications not matching the genuine product.
Jan 07, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
Redistration to other brand DECT 6.0 base failed.
DECT 6.0 IS JUST A MARKET NAME FOR DIFFERENT BRANDS, THE WATERPROOF DWX207 WILL ONLY WORK WITH UNIDEN PHONES, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOES NOT MEAN THEY WILL WORK TOGETHER...
May 22, 2009 | Uniden DECT 6.0 Cordless Telephone...
I have a TWX955 cordless phone. one of the recievers is a waterproof phone. Instructions said the rechargeable battery was already in the phone. (all of the other phones required me to install the battery...
Take the cradle for the waterproof phone and plug it into the outlet close to the answering machine base. Hold the waterproof phone in one hand, with the other press the "menu" button, press up to the "register phone", then press "menu" again. The answering machine base should say "registering phone". Once it does press the "#" key on the waterproof phone and it should say registering phone. When they beep the waterproof phone should be working. The reset instructions in the owners manual may work if you move the WP phone and cradle close to the base. I stumbled onto this method after reading about a newer model. As i took the WP phone downstairs the # key would activate the registering feature but would when I walked back upstairs. So i figured Id take both downstairs and BAMMM, it worked. Good Luck all! BTW mine came with a battery, and uniden probably hasnt figured this out either.
Dec 26, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
1,699 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
