Question about LG WM2688HWM TROMM SteamWasher
Dispenser door stuck
Drawer for dispenser stuck will not open
  • 489 Answers
The dispenser assembly has warped and needs to be accessed from the top.  Remove the top panel to gain access to the dispenser.  The top part of the dispenser can be pried off so you could remove the drawer.
Posted on Sep 29, 2008
My wirpool duet sport is leaking alot of water out of the detergent compartment whats wrong? Please help
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Dishwasher does not dispense cleaning tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
Whirlpool duet washer leaking badly. when it starts filling water rushes out of the detergent dispenser and the bottom of the door.
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite dish washer's soap door doesn't open during when I run the washer
Oct 09, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric softner will not dispense
Check if the dispenser hose at the back of the drawer is clogged. Check also if the plastic tab located at the back of the drawer, the one that open and close softener dispenser is broken or stuck.
Apr 18, 2009 | Kenmore Washing Machines
Tablet drawer,dispenser wont open at all
Hi, well you we need to check the ribbon cable in the door lining to make sure that none of the cables have been broken with the movement of the door. If they are fine then you should replace the dispenser unit if you are getting 240v to the dispenser solinoid.
Get back if you have further problems...................?
Mar 07, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Maytag MAH6700AWW I need to release the door lock--machine is stuck in the middle of a cycle likely overloaded. Will not unlock when i pause or complete the cycle. I have pulled out dispensing...
open the dispenser door you will see a green piece of plastic,pull on it and the door will open.it may be in a little you will have to reach for it it looks like heavy string.
Dec 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Washing Machines Logo
458 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
