Question about Toshiba Satellite Pro 4600 Notebook
Loud clicking My Toshiba Satellite Pro 4600 makes a loud clicking sound while it is running. I thought the hard drive was beginning to fail so I had the hard drive replaced 3 times with 3 different drives. It still makes the same clicking noise. What else would make this sound?
    Genius:
  • 2,028 Answers
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Posted on Jul 24, 2008
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
My toshiba satellite pro 4600 laptop has a error PXE-E61 media test failure, check cable and PXE-MOF existing Intel PXE ROM
This error relates to an antiquated boot system used mostly for dumb terminals. It's coming up because the laptop isn't detecting a hard drive that is bootable or a bootable dvd so it continues down it's list of options and tries to boot from your network card.
This means the harddrive in your laptop is damaged or failing. If there's nothing of importance on the drive or if whatever important stuff is on there is backed up elsewhere. Buy a new drive(or have your local PC shop put one in) and use the factory Toshiba restore disks to get up and running again.
If you do have important files on the drive you can still get it up and running, but save the old drive(pack in an anti-static bag), and contact www.armor-it.com for professional assistance retreiving whatever files you need from the failing drive.
Let me know how you make out or if you need further assitance.
Chris
Jan 07, 2010 | Computers & Internet
It is running very VERY VERY slow. I thought reinstalling windows xp and drivers may solve problem but did not. I booted the system from C drive with windows xp pro in he system. It formats the hard drive,...
You may want to check the hard drive - sounds like it may be starting to fail. When it reaches the point of not continuing does it start to click? If you hear clicking then the drive is having issues and its time for a new one.
Nov 15, 2009 | Dell Dimension 4600 PC Desktop
Toshiba Satellite Pro 4600 Says D Drive is Out Of Memory
One can only venture a guess on this one: your hard drive is partitioned into C: and D:. Physically, there's only one drive, but it might have been split into 2 separate partitions. I'd go from there.
Jun 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Lost installation cd
ask toshiba to send one for a nominal fee.
Nov 29, 2008 | Toshiba Satellite Pro 4600 Notebook
Re install 98se on new hard drive
Try a newer version, windows 2000 or xp.
Im runing windows xp on my 500mhz laptop, yours seems to be 900 witch is more than enought.
if you insist on 98se,
1st make sure your laptop starts up from cd drive from bios
to enter bios press F1 or F2 or Delete Depending on your bios.
drop me a line if you need more asisntace.
Mar 21, 2008 | Toshiba Satellite Pro 4600 Notebook
Satellite pro 4600 windows 98 fatal error
What OS are you running on the system? Did you recently install any hardware? If there is a recent hardware install, remove it and try powering on the system on.
If this fails, then you'll need the restore CDs/DVDs from the manufacturer. This will bring the laptop to it's factory default installation. Before doing so, I recommend purchasing a hard-drive enclosure for a laptop hard-drive and backup all important data.
Hope this helps :)
Nov 25, 2007 | Toshiba Satellite Pro 4600 Notebook
Hard Disk Sound
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Sep 17, 2007 | Toshiba Satellite U205 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
