Question about Creative Labs ZEN V Plus MP3 Player
CREATIVE ZEN V-PLUS. COULD NOT TURN ON AND IS NOT CHARGING
Hi, Gud day!
I was charging my Creative Zen V-Plus with my pc, after quite some time, i checked if it was already full... but when I saw it, it was not charging, it says low battery. when i tried to charge it again by plugging it at another usb port, it will show the sign that it was charging for a second and the image will be almost full but then it will turn into low battery, the red one, a second after...
i could not turn it on again anymore... my computer wont read it either, it turns on but turns off again immediately...
Thank you so much.
  • 9 more comments
  • Anonymous Jul 30, 2008
    ive been out of power for the past 17 minutes so i dont know how it happend but my mp3 player wont work and i cant seem to even get the screen to glow. ive tried to reset it but it still wont work
  • Anonymous Sep 08, 2008
    When i turn on my creative Zen V Plus it'll come on then it'll freeze on the logo (ZEN v plus). I tried resetting it but the problem repeated itself.
  • phatkidsmith Sep 28, 2008
    I have the evact same problem... and when I reset it... nothing happens
  • Anonymous Oct 07, 2008
    I followed the suggestion and it still does not work.
  • yvette marquez Nov 04, 2008
    it won turn on its a creative zen 2 gb mp3
  • liannawitt Dec 09, 2008
    I had the same problem and after trying everything it finally worked with another usb port. I had tried other ports and cords but nothing changed but finally it looks like its charging! Finally!!!
  • marco7soccer Dec 17, 2008
    my creative zen wont charge it wont even open
  • alynddrummer May 01, 2009
    my computer reads the device and i can transfer music to and from it. The screen has not turned on once since ive owned it (for 2 years now) ive reset it, checked my usb power management, reset some more...it turns on for a second and then right back off when it isn't plugged into the computer. raaaaaaaaaaah
  • amn384 May 08, 2009
    The same thing is happening to mine :/ it did this before.... but it all of a sudden starts working randomly usually... I don't like to wait though. It's been over a week :{ Right now it's doing the thing where it shows it's charging (the buttons blink blue, showing that the battery is low, but charging...it's not really charging though. I'm sure it doesn't take DAYS).
  • Anonymous May 10, 2009
    I have a similar problem. The reset does not work (tried with a paper clip) and when I try & update the firmware, I get a message that there is no supported hardware attached (via usb) to the computer. HELP!
  • amn384 May 11, 2009
    Yeah, I've reset it numerous times as well using the end of an earring until I hear the click. It used to work, but now it doesn't. It usually does this either when I attempt to charge it sometimes or usually when I let it die completely (but then I try to charge it, it says it's charging, and my laptop is new, where if it's on sleep it still charges whatever is attached to the USB port and it never charges). I've tried other USB chords as well, it seems to be the player.... When I attach it, it says it's 'docked' or just the buttons will glow blue, but then it shuts down and says it's docked again (which is annoying when every 5 seconds my computer says that my Zen is now attached/docked/charging and the next second is isn't and it really isn't charging...I've left it there for over 12 hrs.... it didn't charge and all that happened was that it was really hot) or it will show the creative sign on the screen and freeze there. Once it started working, but it was attached the computer and the display backlight had faded and some and kept having these black lines show up on the screen.... it worked for a couple min.and then returned to the previous state.
Try using the reset botton while connected to the computer via usb cable , it worked for me.
Posted on May 10, 2009
Could it be the usb cable got damaged some how? have you tried using a different cable with the same results?
Posted on Jul 25, 2008
I got mine back with help from Creative tech. support as follows:
I understand that you are unable to power on your Zen V Plus 2GB player.
I apologize for the inconvenience the product is causing you but please
proceed below for steps to help you fix it.
Please verify that the player is not on screensaver mode by pressing any
buttons.
If you are facing the player, please look over to the left hand side of
the player. The reset hole will be there. Please push that hole using an
object tiny enough to fit in. Please perform this step while the player
is disconnected from a pc and check for any reactions on the display
screen of the player. Verify if it switches on.
If you do not get any reaction, please connect the player to a rear usb
port of a pc then wait for about 10 seconds before
pressing the reset hole. Wait for another 15 seconds before checking the
player display for any reaction. If possible,
try multiple usb ports and computers. Verify if it switches on.
Try using another usb cable as well if you have a spare.
If you only get the battery charging icon, allow the player to charge
for at least 6 hours. During this time, if charging from a USB port,
please ensure your PC does not enter a power conservation mode (Standby,
Sleep, or Hibernate) as this will interrupt charging.
Also, please follow these instructions if you are using Windows XP (home
or pro):
1. right click the "my computer" icon on your desktop, click
"properties"
2. click the "hardware" tab
3. click on "device manager"
4. click on the "+" sign beside "Universal Serial Bus Controllers"
5. right click on "USB Root Hub", click 'properties"
6. click on "power management" tab
7. UNCHECK the option "Allow the computer to turn off this device to
save power"
8. please repeat steps 5 to 7 for all the other USB Root Hub on the list
This will ensure that there is continuous power supplied to the usb
ports of your computer.
Please click the link below for additional troubleshooting steps.
ZEN V or ZEN V Plus Does Not Power On or Charge
= http://support.creative.com/kb/ShowArticle.aspx?sid=28137
Posted on Jul 30, 2008
Plug your device into a Windows 2003 Server R2 box with USB2.0 slots and it should charhe okay.
Posted on Jun 19, 2009
SOURCE: Creative Zen V Plus
hey. for first: reset it, take a needle and put it in the reset hole in the side. connect it to power, best is not from the computer.. and turn on. it will probably rebuildt and so on.
Posted on Aug 20, 2007
  • 556 Answers
SOURCE: user manual for Creative Zen V Plus 4GB Digital Multimedia mp3
You will need Adobe Reader (free) to read the manuals
If needed use the following link and click "Get Adobe Reader"
http://www.adobe.com
link to manuals
http://us.creative.com/support/downloads/download.asp
Click on manual and follow instructions to download.
Posted on Dec 26, 2007
d1g17
  • 40 Answers
SOURCE: Creative Zen V Plus, it charges, but I can't transfer audios.
ok... i found a fix...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
Posted on Apr 07, 2008
ctf1800
  • 4402 Answers
take the back off.
Posted on Apr 24, 2008
SOURCE: Zen Nano Plus problem
The same thing happened to me when I upgraded the firmware from the Creative website. If you find a solution, please e-mail me at jleegreen@comcast.net. Thanks ever so much!
Posted on Jul 18, 2008
My zen wont turn on or charge up and I don't know how to reset it, is there a button??Its a creative zen v plus 1GB
Support site for the Zen V Plus, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_15306,VARSET=CategoryID:213
In the knowledge base solutions Creative gives next answer, when the player does not power on or charge:
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter ( You can purchase the power adapter here as a separate accessory).
  2. Press the reset button and observe the player.
  3. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  4. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, visit SID 29048 in our "Further Suggestions".
Note: If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Reset pin on the left side with the player facing up.
Manual (Multilingual, 17,2 MB) for the Zen V Plus :
http://files2.europe.creative.com/manualdn/Manuals/TSD/9851/0xE85A7F46/Zen%20V%20Plus%20Quick%20Start%20Multilingual.pdf
Nov 24, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Zen MP3 won't charge with mains adaptor
Don't worry that doesn't mean that your mp3 player is faulty, if there is any fault it is from the charger but since the usb charges it well, just continue to use it. It doesn't mean the player is faulty, IT HAPPENS.
Jun 03, 2009 | Creative Labs ZEN V Plus MP3 Player
I can't turn on my zen v plus
try to connect to the pc, it usually turn on when connecting to pc.
Jun 02, 2009 | Creative Labs ZEN V Plus MP3 Player
My Creative Zen Stone Plus is not Charging completely
Use USB 2.0 Port.. My charging status was stuck at 21% till i swapped to USB2 port.. I've tested it and it works..
Regards,
Arvinderan Ganason (Malaysia)
arvinderan@gmail.com
Jan 17, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen won't charge or turn on
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • If the battery is fully depleted, the charging icon may not be displayed.Cupthe player in your hands to check that the blue power LED behindthePlay/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Ifthe player does not indicate a charge, or will not power on afteratleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to takeadvantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | Creative Labs ZEN V Plus MP3 Player
my vision m wont charge. and i just tried to click that button and pluged it back in and its still not working :''''''[
Aug 01, 2008 | Creative Labs Zen Stone Plus MP3 Player
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v plus
If the light is flashing, that means it's charging, but it's possible you're not getting enough charging current to really make a difference.
I would try charging the player with a wall charger (can you borrow a charger from a friend?)
Dec 04, 2007 | Creative Labs ZEN V Plus MP3 Player
Charging zen v plus
Yes you need a creative charger. generic brands usually damage any electronic device. you need to get a creative charger, and hope that it will solve your problem. if not then you may need to ger a battery too. connie
Jun 21, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
3,247 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
