Question about Pentax ME Super 35mm SLR Camera
Shutter stuck was taking a snapshot. Film advance will not advance
  • 1 more comment
  • Gavin Shields Aug 05, 2008
    I have the same problem in that the film wont advance. I have notice however that when the camera has taken a picture the shutter doesnt return fully to its start postion.
    Would it be expensive to have this problem fixed ?
  • Anonymous Nov 01, 2008
    I also believe i have this problem. I cant switch modes, and its stuck on AUTO.
  • Harold Bean
    Harold Bean May 11, 2010
    did the film counter return to zero after you opened the back?
    Scholar:
  • 58 Answers
The is due to soft plastic/rubber parts breaking up. They gum the works, and jam things generally. Getting the camera to release from the jammed condition is just unsticking a gummed up part, and it is likely that after a while unused it will bind again.
Also, as these parts get worse they break up and the debris can and often does get into the more delicate parts. When this happens they must be removed and the works cleaned up. Do not try and coax the camera into operation, if this happens this usually causes permanent damage to the works. (I know. I see plenty where this has happened.)
Go to my camera repair website to see how to fix the problem permanently.
Posted on Jan 21, 2009
  • Gordon Stalker
    Gordon Stalker Jan 23, 2009
    Stuck on auto is a different problem. It has nothing to do with the stuck mirror/shutter.
    The auto switch is released by depressing the little white bump on the slector dial. It is often quite hard to push in. Use your thubnail if it's tough.
    It may also be due to corosrion making it stiff. To fix this the button has to be removed. See how to do it at this pentax camera repair site.
    The spring detent may be damged too. As a last resort this can be removed to allow the switch to be moved, but this will mean the selsector does not snap into the correct position which might make selecting modes a little awkward. Again refer to the above site.
    Novelist:
  • 103 Answers
Hello Gabe529, As I recall, this was Pentax's way of mating electronics with mechanical cameras and the success rate was quite good. The only problem with the Pentax Super Program was the rather complex winding system. The camera is over approximately 30 years old making it a classic. It is no longer in production meaning parts need to be cannabalized from another working Pentax Super Program. The cost of repair would exceed the value of the camera. Look for another good used model or move on to a Pentax DSLR (digital SLR) camera as your tool. Sorry I couldn't give you a better answer on how to fix your problem.
Posted on Sep 27, 2008
I had a problem with my Pentax Super Program.
I took a picture and then wound up for the next shot and the camera wouldn't fire no matter what mode I switched it to.
I was able to get the camera to fire by removing the cap covering the winder connector (on the bottom of the camera, below the shaft for the winder) and "gently" tugging on the little lever that lines up with the two notches on the winder shaft.
The next time I didn't have film in the camera, I sat down and just kept winding and firing until it didn't get stuck anymore.
I am assuming that the problem I ran into is that I normally have a Pentax Winder ME II hooked up to this camera & I don't normally use the winder lever, so it got sticky maybe?
Anyway, I have now switched to using the camera without the winder to cut down on the size of the camera.
Hope this helps someone.
Take care & Happy Imaging!
Yours truly,
Glen
Posted on Aug 14, 2008
    Problem Solver:
  • 18 Answers
Have you tried taking a picture on either the 125X or B mode?
If you are able to take a picture on the 125X or B mode, then it probably isn't the mechanical part of the camera, but the electronics. If so, try putting some fresh batteries in the camera.
If neither if these work, then the camera might be past its prime.
Take care & Happing Imaging!
Glen
Posted on Jul 26, 2008
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
The shutter on my Pentax zx-50 SLR is stuck in the open postion. I can't see anything through the view finder nor will it focus automatically. However, it will advance the film upon taking a snapshot and...
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Nov 28, 2010 | Pentax ZX-50 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Why do all of my pictures turn out blurry?
Either the autofocus does not work any more, or you are not allowing time for the camera to focus and shoot when you try to take a quick snapshot and then move the camera. With these digitals, you should press the shutter button HALF way down to allow the camera to focus, the an LED by the viewfinder will change color to tell you to finish pressing the shutter button. A quick snapshot as with a film camera is fast, but because a film camera is very quick you usually get good results. Not so with a digital camera.
Jun 13, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Pentax super 100 35 mm camera shutter is stuck
gabe529; This doesn't appear to be a digital camera, so this can't be a problem generic to all digitals! This is a film camera. Have you tried new batteries? Have you checked your battery polarity in the camera? Have you taken your film out and wound the take-up lever once or twice, or will it not advance? There are many situations where a 35mm camera shutter won't work. We may provide a better answer if your post could be more specific (i.e. what were you doing before the shutter quit - loading film, taking a snapshot, checking shutter release while the back is open?) Hope this helps somewhat.
Jul 24, 2008 | Cameras
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
453 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
