Question about Pioneer PRO-700HD 64" Rear Projection Television
Will not power up
  • My Pioneer Pro-700HD was purchased new about 9 years ago, never had a problem never been serviced. Last evening there was a “blue” flash on the screen and then the TV went completely dead (powered down). We tried the trouble shooting in the manual to no avail. It will not come back on the Red Power light stays on but will only stay green for less then a second; I hear a “click” inside the set when trying to turn on the power. I would guess it is a power supply board but since I have no expertise that would be presumtive.
  • I am checked the fuses on the board where the external power cord is attached, the 2 glass fuses look fine (wires in tack and no burns) but the third fuse is a solid color and I cannot see inside, I can take it to get tested or replace but decided I should get guidance from you on how to proceed from here. The inside requires cleaning, very dusty.
  • If it is the board at this juncture is it worth fixing or is it time to buy new (Plasma or LCD, not sure).
  • TEFidaleo Jul 26, 2008
    After working with Jamie867 yesterday I began to pull the power supply assembly. I then noticed another bank of fuses and found a 5A/125V (Pioneer part number FU206 per the circuit board) fast burning fuse was burned out. I went to Radio Shack and purchased a bag of the 5A fuses and had the fuse (FU101 10A/250V) tested that I could not see through yesterday and it checked out as good.
    I replaced the burned fused and reconnected the power cord but the fuse quickly turned red and burned out (I did this twice and then unplugged everything).
    Per the partial service manual I purchased yesterday (did not realize there were 2 parts to the manual) I noted this fuse is part of the Power Supply Assembly (Pioneer part number AWV1710).
    Per the pioneer site the power assembly is in stock. However, before I order a $352 part I want to make sure that is the appropriate course of action, i.e. I don't know if that fuse could blow from a problem in another area/board.
    Your recommendations are appreciated. I would be glad to email the Service Manual I have if that helps, it is in a PDF file.
    Thanks,
    Tony F.
    I added updated information not available yesterday please revisit and respond.
    Thanks,
    Tony F.
    Brigadier General:
  • 6,966 Answers
This is not a solution but a suggestion. Perhaps it would be to your advantage to continue working with Jaime867 as he has started. You can always ask him directly through the "Ask Me" feature in his profile here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 26, 2008
    Genius:
  • 2,035 Answers
There could be high current in board which is caused by the short in board you need carefully check each point for that you may need a service manual which will guide to trouble shoot the problem....
  • Anand Kumar
    Anand Kumar Jul 26, 2008
    If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
    http://servicemanuals.vstore.ca/
  • 2,794 Answers
I would check the fuse that you couldn't see through. A set that is 9 years old might be difficult to get a new board for.
Pioneer Pro 700HD picture distortion
horizontal capacitor parts should be replaced...
Dec 31, 2009 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer PRO-700HD HDTV problem
ya u just plug in hd antenna in qam in antenna in cox cable style then scan for chs in tvs menu ok
Feb 02, 2008 | Pioneer PRO-700HD 64" Rear Projection...
All my inputs create a rapidly rolling screen.
EITHER you have bad filtor capacitors in 5 & 9 volt circuits or you have bad electrolitic capacitors in vertical circuit. J.D.W.
Jun 18, 2009 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer Pro-700HD Mirror Broken
Thanks for trying… partstore.com was actually the website that I originally tried ordering from. I feel lame for not including that tidbit of info on my original post because I didn't want to give that site a bad rap. After a bit more reasearch I discovered this site: http://www.highreflectivemirrors.com/ they carry the replacement for only $120 with free shipping and with only a few clicks I purchased it via PayPal. I am currently awaiting delivery and will post again if for some reason it doesn't work out.
Oct 17, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Power problem on Pioneer Pro-700HD
The failure is not on the power supply but the convergence amplifiers STK ICs have the 24 volts shorted.
If that fuse is blowing, de-solder the convergence ICs and put a new fuse to power up the TV; you should see distorted video when the TV powers up and the fuse should not blow.
The service manual migth not help much in this case since the failure is easy to pin point.
Good Luck.
Oct 03, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Tony Fidaleo's Pioneer PRO-700HD
Once I look at the schematic diagram, I might be able to know the part that is blowing that fuse.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
Television not satying on.
It needs to be brought into the repair shop for service. There is nothing that you can do to make it come on. It's just an old set.
C-Dog
Feb 10, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Blue lamp climbs up on a curve from center of screen
convergence sys. Usually they use STK ICs in there, replace them.
Mr Bob
Dec 22, 2007 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer PRO-700HD 64" Rear Projection Television Logo
109 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
