double posted and tests DONE WRONG
the battery must not be dead is first
and not testing fuse, with KEY on,
1;/2 the fuses are dead KEY off that is
100% Normal.
key on does
IP cluster glow lamps as it did just like it did for 13 years?
head lamps bright key on an off both, (it must)
heater blower on high, works loud ,key on,
is the starter motor dead/? called cranking,?????????????
you said new crank , I'm sure you meant a new starter motor>?
is the starter dead? now? if yes post how to test a dead starter.
starters fail in many ways.
- dead
- chatters.
- clicks,
- makes a HUGE nasty loud bang, (engine or it seized)
- or starter spins fast (sounds like sewing machined) but engine cranks shaft never spins (turns ) starter pinon failure.
or starter goes GRRRRRGRRRRRR and crank shaft spins but does not start.(seen and heard)
a dead starter with a good battery (charged) may crank
if you learn to crank it in NEUTRAL. (auto tranny?)
does starter work , JUMPER cable jump started?????
crank in park then try Neutral.
on stick shift cars the clutch switch bad kills cranking.
