Question about Amana Heating & Cooling
Air conditioner won't turn on - Amana Heating & Cooling
  • 143 Answers
Check the circuit breakers and report back here when you know more about the problem, like "Does any part of it run?" "Are there any lights on the thermostat that are on?" "Is it a window unit?"
Posted on Jul 25, 2008
Won't turn on
There can be wiring issue. Try to check it by giving direct power to it and try to turn it on. You will know the issue.
BMW Performance Chips
Aug 12, 2012 | Coleman Mach III Air Conditioner
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
I turned on my air conditioner and it won't come on. It keeps blinking a symbol which looks like an F
blinking F is indicating a fault see the manual that came with the unit, it should instruct you further
Aug 13, 2011 | DeLonghi PACA110 Portable Air Conditioner
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Jul 22, 2011 | Samsung AW1203B Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
132 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
