Normally it is a rusty control valve,
normaly the warm water from the engine heats a radiator inside the car the interior fan then blows air theough this heater radiator making your air inside the car warm.
now in this case you have two radiators and two valves, depending on where you want the heat left or right the appropriate valve will open.
normaly you can follow the water pipes to just before they go into the car there are to grey cylinder looking things with a plug.
You can try taking the valve out, opening it up clean it thouroghly and re assemble.
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
These will help.
Thanks.
