Home
My Products
Sign In
Back to:
All Products
Panasonic
PT-43LC14 43 in. Rear Projection HDTV Television
Troubleshooting
Tags
replace lamp
How to remove the front panel
lamp
lamp replacement
Lamp replacement
posted by
sitkahook
on Jul 24, 2008
Report abuse
we have the back off but where is the lamp to replace?
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on Aug 02, 2008
stl34
Rank:
Apprentice
Rating:
0%, 0 votes
It is located in the front, down at the panel. Remove it and you will see it.
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lamp replacement:
I don't want to Accept this solution
Done
Solution #2
posted on Jul 24, 2008
reddhead141
Rank:
Guru
Rating:
87%, 106 votes
There are three . they look like lens
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Done
Suggest a new solution for this problem
Can you Help with these Projection Televisions problems?
Panasonic PT-43LC14 43 in. Rear Projection...
replacement of Bulb PT-43LC14
I need to replace the bulb on my PT-43LC14. I have...
Answer This...
ADJUST COLORT
cannot get yellows
Answer This...
air filter cleaning
an osd advising air filter cleaning is displayed. were is...
Answer This...
rear projection samsng sp42w4hl
i have got the tv working and now need a service code to...
Answer This...
PT-43LC14 43 in.... Problem
My Lamp blew out. I replaced it. I cleaned out the back of...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Bogda
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
