Acer computers are known to have low quality Power Supply's.
The one in your Acer could have a weak voltage power rail. No, not something that is easily fixable. It's more intelligent to replace it with a KNOWN to be good, Compatible power supply for a test.
1) Monitor not detecting.
In otherwords, No Signal. No video signal because the computer isn't working. LED lights may light, perhaps fan/s spin, but there isn't enough power to turn the Processor on.
A) ALL of the LED lights on at once use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Intel Pentium Dual Core E2160? Can use Up To 65 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29[ TDP = 65W
Thermal Design Point.
65 Watts ]
Known to be good, Compatible power supply:
The Acer M1640 desktop computer just uses an ATX form factor power supply. The kind installed in over 80 percent of desktop computers out there.
Form Factor is a term used for motherboards, but has gone on to other various computer parts.
It refers to the size, and shape of the Power Supply's case, and the power cables the power supply has.
Size and Shape:
Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
Power Cables:
1) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain242) 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain243) Should have at least 2 SATA power cables.
4) Should have one 6-pin PCI-Express power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress5) Two to Four, 4-pin ATX standard Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral{Misnomered as Molex. The name Molex stuck, just like Crescent wrench did for an open-end adjustable wrench }
[ The links to power cables above are part of a main page. Scroll up to the top of the page, and click on the photo - SATA power cable, for more info on SATA power cables ]
Perhaps there is an unused computer, that you can borrow it's power supply for a test unit.
The Acer M1640 just uses a 250 Watt power supply. (ATX form factor)
(If the power supply has more Wattage it's okay.
A Computer ONLY Uses the Power it Needs, and No More.
If you installed a 10,000 Watt power supply, {Exaggeration}, and the computer only needed 100 Watts for what it was doing, it would ONLY use 100 Watts, and No more )
Would like to hear back from you. Post in a Comment.
Regards,
joecoolvette
