Question about GE PSS26SHRSS Side by Side Refrigerator
Freezer door pops open
We I close the frig the freezer door pops open a little bit
no-one seems to notice stuff starts to melt
  • 20 Answers
I know what you mean...... ok, the bottom of the door is not leveled right. you can adjust this by respringing the hinge. put something large like a screwdriver handel in the door and close it slowly. do it just enough to respring the hinge. dont do it to far or it my make it worst. some door have a screw ajustment on them but this dosent work all the time. there is a number of resons why the door does this. i have found that this works 9 out of 10 times. but do it slowly and check it after each time you do it. hope this helps you...............thanks eddy
Posted on Jan 04, 2009
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Refrigerator starts cooling mainly when I open the door
Put a thermometer in both the freezer and the fridge. Fridge should be around 40F if not a little lower, but should stay above 30F.
Freezer should be just below 30.
Feb 09, 2012 | Refrigerators
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Not keeping cold both frig and freezer side.
First you need to check if the compressor is working properly.
Remove the rear panel and look for a cylinder with bunch of copper lines going in and out. feel those copper lines one of them should be warm and the other should be cold. Also you should hear the compressor working (pretty noisy) when the temperature in the freezer is not cold enough. If the lines are about same temperature and the compressor does not seem to work, the first place to check is the starter relay. Often the relay breaks. The part is WHIRLPOOL 2188830 2220475 RELAY. I found one on ebay.
Good luck
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
GE PSS26SHRSS Side by Side Refrigerator Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
