Question about Samsung HLP4663W 46" Rear Projection HDTV
Your tv problem
I posted that I believe it is the color wheel that shattered which would be the pop you heard and I also posted a link on how to replace it. Just rate the other experts' solutions until you find mine. Thanks for using fixya
  • 31 Answers
Sorry but the pop would be a lamp and not a color wheel. the color wheel would make the pic have not color or would keep the set from turning on
Posted on Aug 14, 2008
How often do you have to replace the lamp on a 56DR650? Replaced in April of last year and is now exhibiting same problems.
Average life on a OEM lamp unit is 2,000 hours which usually works out to 2 years (unless you use it a awful lot of hours).Bad color wheels in these sets usually exhibit a high pitched sound or fan like noise--even heard a few that sound like a garbage disposal.The wheel faces the lamp so if you can remove the lamp and look at it to see if shattered or missing pieces.Someone posted instructions for the replacement online--let me know as it is on my bookmark list now.Only way to know (other than taking lamp out and finding it shattered inside) is to replace it.May be the lamp again, maybe the Ballast that drives it etc, kind of like starter on car turns but car will not start.Try to look at turn on to see if lamp even fires for a moment--then inspect color wheel etc. If you want the URL for the installation of the wheel let me know.SD TECH
Apr 10, 2012 | Sharp 56DR650 56" Rear Projection HDTV
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
Color wheel or did i break something else?
Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some sets may actually shut down if the wheel is bad or shattered.
To determine if you have a bad color wheel:
  1. Turn set off and wait for main fan to shut off.
  2. Unplug the set.
  3. Remove the lamp door and then remove the lamp.
  4. In the direction the lamp faces you will see a round opening; the color wheel is facing this opening. It is a round plastic wheel with colored segments—we want to look to see if any of the segments are missing; a shattered wheel should be clear to see.
I have also posted the general instructions for Do it yourself replacement of this part in the TIPS AND TRICKS section of this site.
I will attach a photo of the color wheel for you to know what you are looking for----
If you have any questions feel free to respond to this posting.
If this has helped you rate this solution as I do this here for free.
Jan 01, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
While watch tv last night heard a crakle and we lost the picture on our samsung dpl tv. We got a new lamp and installed it. There is still no picture.
Sounds like the color wheel has shattered and the sensor is blocked by the peices. If the wheel was not blocked you would have a black and white picture.
Jul 06, 2009 | Televison & Video
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Our samsung tv was making loud noises. the color would get distorted and it would turn off on its own. after unplugging it and plugging it back in, we watched it for a short while and we heard a shatter...
That was probably your color wheel being destroyed. This repair is not for the DIY'er you need to see a tech for thione believe me... The light engine housing needs to be removed justy above the color wheel and a new color wheel needs to be installed. Wheels are not cheap 2-3 hundred dollars and you would be surprised how much tear-down the tech will have to do to get at the wheel housing. But believe me it's well worth it...
If you have any problem locating a good reputable tech for the repair you might try NESDA (National Electronic Service Dealers Assn.) or let me know about what city/state you're located in and I can recommend someone.
Good Luck!
Dec 02, 2008 | Televison & Video
Samsung HLN617W
If it is it will be the first I've heard of one shattering... The CW spins at 7200 rpms and at that speed anything is possible. What color is the glass?? Clear and it's not the CW.. My bet is on the lamp. Does the lamp fire up?? You need to do a bit of investigating and let me know and I'll try and help..
Good Luck!
Dec 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
DLP TV Samsung HLP4674w No Picture
If you hear a ticking and or buzzing sound as it is trying to start up then most likely the replacement lamp is bad. Take it out and reseat it one more time to see what happens. The noise you hear is the ballast attempting to fire the lamp up.
Nov 30, 2007 | Samsung HLP4674W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
