I'm not using my external hard disk for quite sometimes. just now, when I plug in, its' shows no connectivity. When I click the 'safely remove your hardware, its shows that my external hard disk need to do formatting before use. i agree then click format, or click cancel for not to proceed formatting. What would be happened if I proceed with format? All my data will lost? Please advise what should I do....
Use MySafe to back up the files stored on the Ethernet Disk mini Home to
an attached USB storage device. This way, if files on the Ethernet Disk
mini are damaged or accidentally deleted, you can restore them to their
original locations. There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary) Before you can back up files, you need to connect a hard drive to your
Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible. While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back
of the Ethernet Disk mini, just like you would connect the external
hard drive to your computer.Confirm that the drive is
properly connected. Log in and click on the Administer HipServ link.
Click on USB External Storage under System. To back up files, navigate to the file or folder you want to back up to
the external hard drive and click on the disk icon in the "Backup"
column of the file list.When you back up files to MySafe, the
Ethernet Disk mini duplicates the file path in MySafe so that everything
you back up is organized in MySafe just as in its original location.
So, if you copy a file from MyLibrary, a MyLibrary folder will appear in
MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage
before unplugging your MySafe external hard drive. Wait for the
interface to change and for the Use Drive button to appear before
disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before
disconnecting the USB cable can cause data loss and/or damage the drive.
Always use the Safely Remove Drive feature when disconnecting an
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Has the hard drive been formated?
To format the drive, plug the external drive into the USB port - go to the Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. The External drive should be listed as USB drive. On the lower panel, right click on the USB Drive and click on Format, and format it in NTFS.
After formating you will be able to use it as a normal hard drive.
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Try these steps:
- Right-click on "My Computer"
- Click "Manage"
- Click on the "Disk Management" icon in the left column (Under the "Storage" category"
- If your disk appears on the right-hand side, then try to right-click on it and create a partition.
The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list
