How do i change tv from antenna to get cable channels?
  • 68 Answers
Kindly clarify your question pls...
Posted on Jul 24, 2008
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Why won't hd channels be found when I tune my 42
It depends where you are. Digital has replaced analog signals. If you don't receive channels, ask a friend or neighbours on the situation with their TV. If their hd TV are working properly, then you may have not tuned the TV properly. Have you chacked the Antenna cable? Yes? Then tune it with care and watch what happens. Normally, the TV will show if a signal has been detected. If you have no signal, you need a technician because there are more than one reason this is happening, probably you haven't connected the Antenna cable. Who knows. Again, check the antenna cable, is it lose or wrongly inserted? If you have a small digital TV, connect the antenna to that TV and see if the channels are working. If not, it's probably the cable from the wall socket to the TV (change the cable) or the Antenna cable had been a meal for a rodent on the roof. As I said, who knows?
Oct 17, 2014 | Televison & Video
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
I can only able to see 65 channels in my new samsung t.v[LCD]but in my calbe there are more tahn 70 channels....how can i see the all channels
When you scan for channels, make sure you choose "cable" for the setting under the "Antenna" tab.
channel --> antenna --> choose cable
This should let your TV show more channels. Most cable companies issue cable boxes now a days, which you plug into your TV. You usually change the channel by using the remote for the cable box.
Hope this helps
Mar 13, 2011 | Samsung LN26A330J LCD TV
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Cant change channels?
What is your antenna source? Cable or antenna? Try keying in a certain channel on your remote. see if you get that channel. Tv will not auto program if you do not have channel source coming in to antenna input.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Cable/antenna
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
http://129.33.22.12/release/KDL40XBR4.pdf
May 16, 2008 | Televison & Video
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
