Question about Whirlpool LHW0050PQ Front Load Washer
Water not draining.
My washer goes through all cycles and it spins but the water doesnt drain out. I cant find any clogs and I'm not quite sure how to check the pump but i think its working. Any suggestions please
  • bwyellowjack Jul 24, 2008
    Thanks a lot. I am going to get right on this. I appreciate it. These machines are junk. I'll never but another whirlpool as long as I live
  • kimberlieran Jul 29, 2008
    my washer goes through all the cycles. then will cut off because the water will not drain.these washers are brand new and now im stuck with them and i am told i can send them to service
  • 5,911 Answers
If this is a Whirlpool front loader, the only thing between the standpipe and the wash tub is the drain pump and drain lines. If you have not found any clogs in any of the drain lines, and if you can rule out a plumbing issue with your household drain system, you probably have a bad drain pump. The pump may be running, but if the impeller is damaged, or the motor gears are stripped, the pump will not drain the water from the wash tub. I would recommend replacing your drain pump. There are several good websites available for ordering replacement parts. I recommend searspartdirect.com, because they also provide excellent exploded view illustrations of the appliances, making it easier to locate and identify the correct part numbers. You don't have to use their service, but you CAN identify the part number, and shop around if you like. They do offer competitive pricing with most things though. Repairclinic.com also provides excellent service and you may find the same part there at a cheaper price. You can use the following link for step-by-step instructions on how to replace the pump:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Keep in mind, the symptoms describe a pump that is NOT running. This is not neccessarily true (as possibly with your situation). In addition, your pump may not have an access cover to remove (depending on model number). Some Whirlpool models have drain pumps that you have to remove the drain line in order to check the impeller and clean. I hope this helps you. Let me know if you require further assistance.
Posted on Jul 24, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Why when the machine finish washing it stops and will not spin the water out
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Jun 10, 2015 | Washing Machines
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Washer doesnt fully drain and fills water in on the spin cycle
There is fault on the drain pump, check the tilt of the machine and allow a slight tilt towards the drain so that the residual water flows out easily. If not the drain valve is clogged, check the drain filter.
If the cycle keeps on repeating or going back it can be due to fault within the controller unit or memory.
The leak can be due to failure of the lid washer/gasket which can be confirmed by observing the edges.
Mar 20, 2013 | Washing Machines
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal De
