Back to:
Tags:
RCA RTD258 System
System won't power up
posted by a6291 on Jul 26, 2008
I need a new power supply circuit board. The one in the unit is fused at 3.5 amps and the board will blow that fuse instantly just plugging the unit in. I have unplugged all the connections(except power) to the board and the fuse still blows. I need a new board. The info on the board: rtd 258 smps bd mp, tm# 56104590. Made 2/17/06. No help from RCA. Any ideas? Thanks, Allen
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 26, 2008
Not Rated (0)
Jaime867
Rank:Guru Guru
Rating: 87%, 606 votes
There seems to be a short-circuit in the rectifier or any other polarized component in the circuitry.
If you are able to fix the power supply yourself, it is worthy.
It appears that there are not service parts available for you device, the only way is to fix it to the component level.
Let me know if you need further assistance.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on System won't power up:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2443 votes
Based on your description, we can limit the fault to the power supply board and in particular to possibly 3~4 components:
  • bridge diode;
  • filter capacitor (mains);
  • regulator;
  • filter capacitor (secondary).
blown fuse indicate a short in any of these.
As Jaime867 has suggested, in the absence of a readily available replacement board, component level might be the best alternative at the moment. Having posted the most likely culprits further narrows down your troubleshooting. Could you pls post back the part number of the smaller IC either 4 or 8 pins?
Alternately, pls check for the presence of a VDR, it would look like a coin (often green in color or something else) with 2 pins. They have been known to short out also and cause fuse to blow. One possible indicator is chipped or flaked of one side or a hairline crack on top. If it is chip, there would be a silvery color on the inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Thank You!
Can you Help with these Home Theater Systems problems?
RCA RTD258 System
Hello I have an older tv with composite video in and out...
RCA RTD258 System
I just bought RCA RTD258 and the audio sounds great when...
RCA RTD258 System
I could not find an optical cable slot/jack in this...
RCA RTD258 System
dvds will not load or even new dvds will freeze up.
RCA RTD258 System
I have looked everywhere and I can't find the code for a...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
