Monitor image size
I have a inspirion 531 computer with a 17 view sonic monitor.
when i click on a web page it will not fit the screen. it has a 2 " border on each side. i have tried all the adjustments as far as settings etc.
it has a full screen when looking at games etc.
  • jennifer22 Jul 26, 2008
    maybe i was outta line a little. excuse me.
    the menu bar is the full span of the monitor screen, the web pages are smaller. i use a dell computer at work with a 17" dell monitor and i have full screen with everything!!!!!!!!
    my problem
    is as if the page below the menu bar is shrunk in by 2" on each side.why would a web page be ok on one computer and not the next,,,,,,,,,,,,in reality it looks as if i am viewing a 22" monitor where there are margins on each side. there has to be a solution to this!! why buy a 17" unless you can use 17".
    everybody else who has a 17" or a 19" can view without margins. thxs
  • dannyrossdan Aug 02, 2008
    not using the full screen
I think it is a shame that we cannot get a full screen on a 17 monitor .
Posted on Jul 25, 2008
  • 3,940 Answers
There is nothing wrong with the monitor, the issue is that the web page you are looking at is designed for a lower resolution than you LCD is set for (Web pages are normally designed for 800 x 600 or 1024 x 768) you like have a wide aspect ratio monitor.
As I sit here writing this on my 12" wide aspect LCD I have a 2" wide white space on each side of my screen due to my 1280 x 800 aspect ratio.
The issue is one of WEB PAGE DESIGN not the fault of your computer video settings. The web page is written using page frames and fixed aspect ration settings to ensure that the page displays properly regardless of monitor type.
If you had a high end LCD (WUXGA 1920 x 1200), the web page would fill the upper left 1/4 of the screen.
If you lower the resolution of your display, then you'll have fuzzy icons and text, so essentially, get used to it.
Eventually, wed design will catch up with current display technology.
  • IQUIT Jul 26, 2008
    If I may ask, exactly what was inappropiate in my response?
    I explained WHY the page displays the way it does.
    OK if you do agree that the Inappropiate rating was out of line, could you change it?
    As for why some wide aspect screens show full screen where others don't again it is the resolution of the LCD itself.
    The lower the resolution (WXGA is the lowest wide screen resolution LCD at 1280 x 800) will show the screen fuller/wider than a WSXGA (1440 x 900) , WSXGA+ (1680 x 1050) or WUXGA (1920 x 1200)
    http://en.wikipedia.org/wiki/Computer_di...
    You can get a fuller screen by reducing the screen display resolution, but if you do that on an LCD you will sacrafice some clarity on the image as the screen will have some blurriness if not set to the OPTIMAL resolution of the screen design.
    If you are using windows XP you can mitigate the blurriness SOME with the cleartype tuner.
    http://www.microsoft.com/typography/clea...
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
Tip
Setup Menu for MAG LT776 Model 780
I had a blank screen and went through the Setup tips here (in the blind) only to discover it was 3 bad caps on the PCB. I replaced them (tight fit) with more low-profile ones. They were swollen only, not burst or leaking. I put new 220uf 16V ones in, got my screen back.
I realized that it would be helpful if there were an image available for anyone troubleshooting, especially if not familiar with this model, or it's setup. I made the following image, maybe it will help someone in the future.
I see the image is resized for the forum, here is a link to a full size (700 x 850) viewing.
Full size Setup Screen
on Jul 17, 2011 | Mag Innovision LT776s 17" LCD Monitor
Thin text is not properly visible
mcdevito75 here, From your home page, right click on view at the top of the screen, from the menu place your mouse on Zoom for choices and or Text size for better viewing on your screen. Hope this helps.
Jul 14, 2010 | HP L1702 17" LCD Monitor
Screen image size
Try Resizing The View Of The Screen With The Buttons On The Front Hit The Menu Button Then Re-size Buttons This May Help Try Both Width And Height
Jun 07, 2010 | LG Flatron L1750S 17" LCD Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Monitor
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Best resolution
if you right click the desktop then scroll to properties, then click on the settings tab, you can change the screen resolution from there
Dec 20, 2007 | Gateway FPD2275W LCD Monitor
Cannot view Webpage
I guess you can simply increase the size of the text.....it will proberbly offset the rest of the web page but you can read it at least.
What browser are you using?
For firefox and internet explorer do this:
Click on 'view' on the toolbar at the top of the screen. Then click 'text size' for a choice of different sizes.
Did this help at all?
Nov 28, 2007 | Acer AL1716 17" LCD Monitor
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
791 people viewed this question
David Payne
David Payne
