Question about Kenmore 53642 / 53644 Side by Side Refrigerator
KENMORE REFRIGERATOR THE PAINT IS PEELING OFF THE DOOR AND IS RUSTING. CAN I PAINT IT?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Posted on Mar 11, 2008
aborcass
  • 2651 Answers
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
  • 8 Answers
SOURCE: sub zero paint peeling
I have found no fix for this. I have tried repainting but it is not long before the paint is falling off again. Get ahold of sub-zero and tell them of the problem.
Posted on Jan 23, 2009
I have rust on front door of Kenmore side-by-side fridge. Unit is not that old. Can I sand, prime and repaint?
You can but be aware if you use spray paint, the over spray may get into the ice box and onto the liner. Been there done that. It would be best to remove the doors but that is a lot of trouble. If you use a high quality paint like BLP brand rustoleum and thin it a bit using paint thinner, you can actually brush it on but you will still be able to tell it was brushed on. Some people do like that though, looks antiqued. To me its tacky. No pun intended.
Feb 10, 2011 | Kenmore 53642 / 53644 Side by Side...
Go to www.applianceart.com
These guys offer refrigerator covers in a variety of colors and designs and even have stainless options available.
Sep 19, 2010 | Kenmore 57029 Side by Side Refrigerator
Yes for sure, youmust first remove all the rust, remove the beadings gaskets and use a primary coat of rustproof primer.
Now use some tinkering with levelling and cleaning with water paper before you can paint with a good coat of food grade paint.fit back the gaskets, wash the fridge with soda and soft detergent
finally polish and wax ,
Sep 19, 2010 | Kenmore 53642 / 53644 Side by Side...
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Duet gas dryer drum has peeling paint
We have had Ge dryers for years and they all have had paint peal caused by snaps and zippers hitting it over time there are limit switches that should protect from excess heat and shut the dryer off. For a long time Ge laundry products were not very good quality in my opinion I am told they are better now. Just keep the lint screen clean to help air flow, my opinion is that it is more of a cosmetic problem than a safty one. When you can buy a kenmore or maytag.
May 11, 2009 | GE DBXR463EDWW Electric Dryer
Black on ice
i would inspect the "black dots " a little closer, the ice maker mould itself is painted with black teflon fininsh if indeed the mould paint is peeling id empty that ice and replace the icemaker
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Sub zero paint peeling
Jan 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Nov 30, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
