Question about Goodman CKL60AR60 Air Conditioner
Goodman unit freezing outside the unit
Our Goodman unit is freezing up at the base on the part that is connecting the unit to the pipe that connects the unit to the house. My husband's friend is a HVAC man by trade. The compressor went out last year and was replaced by a brand new compressor. The HVAC man (my husband's friend) has done sevaral things;
1. He has cleaned out the coils and filter very thouroughly.
2. He has checked the freon level and added what needed to be added.
3. He is coming this evening to look at the thermostat.
I guess what bothers me is that he is supposedly an HVAC professional, but can't really figure out what the problem is. Maybe he is doing an elimination process of some sort.
To summarize, this unit is freezing at the part that connects the actual unit to the pipe that connects to the house. When this happens, the unit keeps (for lack of better word) blowing. Although the air that it is blowing is just warm air, not cold at all. Not that I know anything about ac units, (which is why I am on here asking some of you fine men your opinion) but I was thinking for sure that it was dirty coils and/or filter - this just from what I have read about Goodman units. Also, the fact of us having dogs in the house led me to believe the above idea.
I am sorry this is so long. I sometimes say too much or make things more complicated than they are. I desperately hope that one of you great guys can give me some advice on what you think it may be. I will be ever so grateful.
Kim
    Problem Solver:
I have a scroll compressor trying to start but won't i can hear it kick in but as soon as I hear it, it kicks out i can't get a reading for pressures cause it won't stay on long enough but i put my amp probe on it and seen amps jumped to about 907 then it kicks out could this mean bad compressor or low on charge
Posted on Aug 23, 2008
    Champion:
  • 254 Answers
Its not the thermostat.
The things that can cause this problem are lack of or poor airflow over the Evaporator coil. Or a low system charge. Or quite possibly a restriction in the line on the low side. When they replaced the compressor did they purge the line set with nitrogen and pull a deep vaccum? This is imperative when replacing a condensing unit to ensure that no residual particles are left in the line set to create a restriction.
Hope this helps You
please rate me
Posted on Jul 25, 2008
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman AC unit
It doesn't look like the other 4 were used. Unless when it got "yanked" it also got cut. I am betting you don't need them though.
May 14, 2013 | Heating & Cooling
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
My goodman unit is freezing up. It is frozen from the line running out of my house than if u look down into unit, the freeze continues inside
Hello, the suction line will freeze either due to low airflow such as dirty air filter, blower wheel, evaporator coil or a weak blower motor. Also, a low refrigerant charge can cause the suction line to freeze up.
Jul 16, 2012 | Goodman Heating & Cooling
How o connect the condesor tko the evapoter
with insulated cooper pipes that are usually purchased with the unit, just make sure not to crease piping. They screw into the condenser and evaporator. Once lines are connected then open valves. Hope this helps tim
Aug 29, 2010 | Goodman CKL42AR42 Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman 3 1/2 ton unit
I work for a very large reputable goodman dealer. Your equipment appears to be a correct match. The correct orfice should have been taped to the outside of the outdoor unit in a baggie right beside where the pipes connect. Things will run alot smoother though if you scrap the orfice and have a TXV installed (thermal expansion valve) . This is a mechanical device that adjusts the flow of freon into the indoor coil based on the immediate needs of the coil. After that, balancing the refrigerant is a piece of cake as all we need is about 10 degrees of subcooling to make sure we have plenty of liquid to the TXV.
Jun 08, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
188 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
