Question about HP LaserJet 2840 All-In-One Printer
How to install new ram into the 2840
Hello, I've called HP and can't get an answer on how to install the 128 mb upgrade of ram into the slot. The only slots I see visible on the machine are the photo memory card slots but I want to add more RAM to the actual printer memory as it only comes with something like 96MB of RAM installed. I've also looked through their manual to no avail and on the Internet. Do you know how to do this? Thanks
  • davidskys Nov 25, 2008
    I've ordered and installed a 128MB memory DIMM (twice!) in my Color LaserJet 2840 per your instructions, but the memory isn't recognized. The HP Toolbox and Configuration Report both say the slot is empty and the total memory still shows as just 96MB.
    Is there anything "magical" that needs to be done? I've already updated the firmware in the printer, unplugged it, installed the memory, waited multiple times - anywhere between 5 minutes and 5 hours - before plugging it back in, and the additional memory is still not recognized.
  • Anonymous Apr 18, 2009
    I can't get the updated memory to show.
  • 138 Answers
Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
Simply click the memory into the blank slot and replace the cover.
Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
Good Luck
Posted on Aug 05, 2008
  • 4 Answers
You can find the extented memory slot on right hand side of your printer.
Open the outter cover. This cover can be removed from the hing. Behind the
outter cover is a metal encloser with a removable cover. There you will find a
100 pin memory slot.
In the past two days, I tried upgrading the memory on my 2840. So I purchased
a 256mbPC100(100-pin)SDRAM memory card. It did not work (damit). The
extra memory prevented the printer from entering the calibration cycle on
start-up. I still do not know why it did not work. If you find why it didn't work,
please clue me in.
Posted on Aug 03, 2012
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Does Toshiba Portege 3490CT ram can be bigger than 128. If so adv availability & selling outlet please.
The motherboard has 128 MB memory (soldered on board). However there is still empty slot for further upgrade. You can install another 128 MB PC100 SDRAM memory to get maximum of 256 MB.
CompQ
May 09, 2010 | Toshiba Portege 3490CT Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
HP deskjet requires minimun of 128 Mb ram. My computer has 128 Mb ram but the printer doesn't still works.
First uninstall the printer driver and restart the machine then again reinstall the printer driver using typicall settings , after installing the driver again restart the machine then check
May 26, 2009 | HP D1560 Deskjet Printer InkJet
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
HP LaserJet 2840 All-In-One Printer Logo
2,360 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
