Question about Miele Cat & Dog 326i Bagged Canister Vacuum
Wiring diagram I havea Dog and cat appart and are trying to understand the wiring. From the power side I have a black then another black for a individual terminal each and 2 x blue coming from a single terminal on the 3 pin plug side. This is passed thruogh the switch to a 4 x pin terninal strip that has a brown yello blue and blak from top to bottom. Can any body help me with a wiring diagramm so I can traced these wires?? The problem with the vacuum is that the motor is not running. I am trying to determine (with the use of a miultimetere) if power is getting to the motor. The motor/fan assembly has a semiconductor switch (SCR?). There is a 5-pin connector that has WH/BK = AC; RED/RED that seem not to go anywhere; and a GY. The mating connector has only the WH/BK (AC) wires (only). The RD/RD/GY wires seem to be floating. There should be some connection between an ON/OFF switch and the SCR gate. What is missing?
    Master:
  • 382 Answers
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Posted on Jul 24, 2008
How to replace three wire on a Oreck U4180 motor
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/2e7c587.jpg
ck out these wiring diagrams. usually black goes on 1 side where the black dot is and white is piggy backed on the opposite side.
Good Luck
Aug 30, 2015 | Oreck Vacuums
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Oct 27, 2017 | Vacuums
Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Wiring diagram
Check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often.
Jan 17, 2008 | Miele Cat & Dog 326i Bagged Canister...
G4 Footswitch wiring
I have published an online guide...it may be of help to you. Just click on the link to view it.
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
May 25, 2007 | Kirby G4 Bagged Upright Vacuum
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
214 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
