Question about Polaroid i733LP Digital Camera
Cracked Screen (?)
We think the screen is slightly cracked. All we can see is vertical black lines and a small ) type mark. Can we get it fixed or would we be better off getting a new camera?
  • fuentesa Oct 21, 2008
    well on of my friends sat on my camera .And it still works but u cant see anything on the screen it is black and white .Also it looks cracked from the inside of the screen .
  • Anonymous Nov 09, 2008
    same here. i don't know what to do and i don't have enough money to buy a new one.
I happen to have one if your interested........it not that hars to replace........thebrain9@hotmail
Posted on Sep 04, 2008
I have the same problem and i never droped the camera! it was working just fine and i had just showed someone a video on the camera then i shut it off and when i turned it on again the screen was broken.. I tried calling polaroid since the camera is still under warrenty but they dont cover the screen..
Posted on Aug 22, 2008
SOURCE:
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How to adjust headlights, 05 ford 500
Headlamp Adjustment
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical left (VOL), visual optical right (VOR) or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is 1 of the following:
    • SAE
    • VOL and SAE
    • VOR and SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using 1 of the following methods as applicable.
    • Photometric aimers can aim VOL-, VOR- and SAE-type headlamps only. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim VOL-, VOR- and SAE-type headlamps only.
    • Mechanical aimers cannot be used with VOR- or VOL-type headlamps. Aerodynamic lamps that can be aimed mechanically have 3 nibs molded into the lens of the lamp.
    • Photometric Aiming
      1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
      Screen Method Aiming
      All headlamp types NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
      NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
      NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
      1. Before starting headlamp adjustment:
        • check the tire inflation.
        • check that no other load is in the vehicle other than a half tank of fuel.
        • check that the headlamps are clean.
        • check for correct headlamp operation.
        • check that the vehicle is on level ground.
        • if the vehicle is equipped with air suspension, make sure that the switch is on.
      1. NOTE: The vertical wall or screen must be a minimum of 2.4-m (8-ft) wide.
        Park the vehicle on a level surface approximately 7.6-m (25-ft) from the vertical wall or screen directly in front of it.
      1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield internal to the lamp (crosshair or other mark).
        Mark a horizontal reference line on the vertical wall or screen.
        1. Measure the center of the headlamp height to ground and record the measurement.
        1. Make a 2.4-meter (8-ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
      1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
        Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
      1. NOTE: For SAE-type headlamps, the appearance of the beam pattern may vary between vehicles.
        On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
      2. SAE-type headlamps
        1. In addition to the horizontal line marked in Step 3, a pair of vertical lines must be marked at the center line of the headlamps on the wall or screen.
          1. Mark the center line of the vehicle on the wall or screen.
          1. Measure from the center of the headlamp to the center line of the vehicle.
          1. Make two 1.5-meter (5-ft) vertical marks (using masking tape) on the wall or screen at the same distance from the vehicle center line as previously recorded.
        1. On the wall or screen, locate the high intensity area of the beam pattern. Place the left edge of the high intensity zone even with the vertical line corresponding to the headlamp being adjusted.
How To Aim Headlights EricTheCarGuy
Jan 15, 2011 | 2005 Ford Five Hundred
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Gets sound but a line through the screen with no picture
If the main PCB is not cracked too bad, it should not be expensive to repair. You have lost vertical deflection causing the flat line.There may be a crack at the flyback, where the vertical IC gets its operating voltage, or a crack at the pins of the vertical IC itself.
Oct 15, 2009 | Televison & Video
Black vertical mark on computer
If it is an LCD monitor it sounds like the monitor got cracked when you moved it. Either that or one of the edge connectors has gotten damaged and is causing a dead column of pixels.
One other possibility is a bad video card or video cable, hook the monitor up to another computer and see if the line is still there, if not, video card or cable. If line is still there then there is either a crack or bad edge connector. Crack there is no fix, except a new monitor. Edge connectors can sometimes be repaired by the appropriate service technician.
Good luck
May 10, 2009 | Computers & Internet
Vertical line on teh left side of the screen
It definately looks like a mechanical defect with the screen. If you see the line when the set is shut off this means that the screen may have a crack in it, or there is a defect in the substrate.
This type of fault is fixed by replacing the screen assembly. The cost of this would not be worth it.
Jerry G.
Dec 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Single horizontal white line on screen
This is either bad connections at the vertical IC or a defective IC. This should be a small flat IC attached to a heat sink. It will be marked LA7837 or something similar. It will have about 11 pins. If you are not sure you have the correct one, post the marking here and I'll confirm.
Dan
Nov 17, 2008 | Symphonic ST427FF TV
Vertical lines
The red line in the crt is the sreen voltage is to high or bad tube.
A simple fix is if you take off the front panel there will be a black box be careful it is high voltage make sure you are a pro.
there will be six controls look for the one marked screen and is for red tube adjust very slightly counter clockwise.until red
line gos away. If that does not fix it its the red tube.
I hope this helps doctor video
Sep 21, 2006 | Akai PT5598HD 55" Rear Projection...
I have a growing black horizontal line on my screen.
sounds like that there was a small ding or crack in the crystal display and as all glass does when it gets cracked the crack will grow. unfortuatly theres not a thing to do untill it breaks or live with it Sorry about the bad news.
May 12, 2006 | Gateway FPD 1750 17" Flat Panel LCD...
Polaroid i733LP Digital Camera Logo
98 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
