-   I have the same exact unit. I was told that the freon was low or that it may have leaked onto the coils.-   mslakisa
Aug 21, 2008
-   My dehumidifier was working fine --- but I noticed warm air coming out of it one day -- and a week or so later it was freezing up despite the anti-freezinag feature on the machine. Does this mean the freon is low - or gone? Is it repairable?-   rasmus2
Jul 25, 2008
-   my maytag M7DH45B2A doesn't collect water anymore.
What is the problem?
Please let me know.
Thanks,
Nathan-   nhkim
I have a model M7DH65B2A that had the same problem. The metal clip that holds the frost sensor to the evaporator coil had rusted clear through and the sensor was hanging in midair. Not knowing whether I could get a replacement, I re-attached the sensor securely to 2 of the loops of the coil with nylon ties and a bit of thermal heat sink compound, available at many electronics specialty stores. Problem solved. You may want to get the correct parts to repair your unit, but I chose to go this route because my repair will never rust through.
It will be difficult but let me explain how to arrive at a point of investigating.
Note
where and how far the frost starts to go by noting on the cold coil
where the frost is and how long it takes to develop. IF it starts only
after several minutes and progresses to cover the face all at once (or
steady and within Id say within 1 hour the whole face) its most likely
fully charged and the control is weak or bad or it could be operating
in too cold of an environment to dehumidify correctly, usually the temp
has to be 80'F or more for the dehumidify to work without freezing.
Also Low air flow from the circularity fan can cause the face to freeze
up in this manner so run it on high speed if the temp is low to keep
warmer air pulling over the coil. If your in proximity to the blower it
will be cold but you have to decide on cool and damp or cold and dry.
If
the temp is above this 80'F and the face freezes up and usually starts
to freeze up on the refrigerant inlet end of the coil and slowly moves
across the face to the other side and progresses back and forth til the
whole face is covered it is most likely low charge. This can also be
noted by thicker frost or ice closer to one end or maybe the bottom
than at the top. and often it will not cover the whole face for a few
hours.
The humidity switch (Hydrometer sensor) may be at fault or compressor
or fan is not running.First You could go directly to the compressor and
make sure it is or is not
getting power first. If the compressor has power then the compressor is
suspect (sometimes when 1 wont start it gets hot to the touch) In any
case the fan(s) should run with it on and trying to dehumidify. Look
at my tips and tricks for compressor check out if it has power and
dosn't run..
2 KINDS of CONTROLS for your DEHUMIDIFY
If it has an electronic display the sensor will be a small probe close
to the inlet of the air inlet circulation. Maybe its not in place.This
type control is not something that can usually be checked without an
ohm meter, thermometer, and Hydrometer or Psychometric measuring device
to arrive at the wet-dry bulb temperatures thus determining the
humidity and charts to determine the resistance value of the sensor(s).
So replace the board and sensor on this type.
As for the drain most have a plastic pan and this is sometimes the type that has to be removed and dumped or a hose has to be attached and the hole it attaches to has to be cut out for self draining.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Maytag M7DH45B2A Dehumidifier
it doesn't collect any water in the bucket . i haven't used it in weeks and when i runed it for a...
(More)
it doesn't collect any water in the bucket . i haven't used it in weeks and when i runed it for a night i noticed it does'nt collect any water . tryed it several times but without luck. thanks menn.
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell...
(More)
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell me a new bucket?
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has...
(More)
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has always worked great until this week. It seems to still be working, but there is a large wet spot in front of the unit which sits on carpet, so I know it is leaking somewhere, but the water bucket is still filling, and I can't see where the leak is coming from. Should we bother having it repaired or just purchase a new one. I am not sure what the life span on this item is. Has anyone had this issue?
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing...
(More)
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing this noise? What do I do to fix it? It's 4 years old.
