Question about Planar PDP-42BK 42 in. Plasma HDTV
No picture - green to red indicator ( do have power )
Hi--
I'm having the same issue reported with my planar tv:
Turn the unit on and I can hear the unit click on when it turns on and goes from Stanby (red) to Green and back to red again.
Checked out the solution reported by lwin62 at:
http://www.fixya.com/support/t292774-parts_needed
But i'm confused by this, as the parts he listed to replace don't look at all like the parts on the board:
"Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went."
EF6225-ND 2.2UF/630VDC METAL POLY CAP
E6105-ND 1.0UF/630VDC METAL POLY CAP
I tried to ask lwin62 for clarification, but don't think he is checking this site anymore.
any help is appreciated!
thx!
  • waldo1599 Jul 24, 2008
    thx for the prompt responses!
    1. no apparent bulges
    2. have not tested them ( was primarly going with the similar symptoms of the other posters and resolutions )
    I have to admit that i'm not very experienced at doing work at the capacitor level, just minor stuff here and there.
    So what gets me is that the board labels show the caps ( per lwin62's board picture ) as the large blue items next to the yellow coils. But the replacement parts he listed from digi-key look more like the capacitors that i'm used to seeing. There is a huge difference between the sizes of the parts.
    thx again
  • waldo1599 Jul 25, 2008
    Ratings on the parts to be replaced? That's where i'm confused on this entire thing. If i am even looking at the same items that they replaced in the post.
    My board looks exactly like the pic posted by lwin62. I'll post a pic of mine with the caps in question.
    thx again!
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Tv turns off will turn on then off right away
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Sep 19, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Planar Plasma PDP-42BK Power issue
You might want to contact them at http://www.planar.com/Products/TV_Large_Screen/plasma/index.html from there you can go support and then on line custumer service.
Oct 13, 2006 | Planar PDP-42BK 42 in. Plasma HDTV
Planar PDP-42BK 42 in. Plasma HDTV Logo
54 people viewed this question
Top Planar Televison & Video Experts
JonSnell Electronic
JonSnell Electronic
Greg Hull
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
