Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Mac laptop won't boot up
Laptop won t boot up light blue screen with a question mark within a file folder icon
Used the DVI to VGA adapter to play a DVD prior to this
  • 163 Answers
Could be hard drive crash.. Try loading MAC OSX from CD to see if it will fire up.
Posted on Jul 25, 2008
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
Just purchased an Optoma PK -201 pico projector. I cannot get it to display anything from my Mac Book Pro. Just bought the VGA cable and I have the screen resolution set correctly. When I plug the...
I had this same problem too. You have to reboot your mac. Either that or the cable you got for it is wrong. Some cables on ebay look identical to the ones that work, but they don't work. Give the rebooting a try and make sure all the cables are tight, especially the dvi to hdmi converter cable.
Feb 20, 2011 | Computers & Internet
How do i hook my samsung spl300 projector to my mac book pro
You can connect your Projector with the Mac Book Pro; However the problem is, mac comes with a DVI connector and your projector uses a VGA one.
You need to buy a DVI to VGA adapter from Apple if you don't have one already. You can buy it from the local apple stores or an online apple store.
There are two types of DVI-VGA adapters available (Please check the below images and see which one fits your Mac and go for it). Apple DVI to VGA Display Adapter
Apple Mini DVI to VGA Adapter Once you decided which one you need, go to an apple store or online apple shop and buy one.
Hope This regardsNextDoorNerd
Jul 30, 2010 | Samsung Mac Notebook
Having trouble connecting my mac to Dell projector screen
You need a external Mini DVI/Dispay/DVi to VGA/DVI adapter to connect it to projector.after connecting restart the autometically detect the display
Jan 10, 2010 | Apple MacBook Pro Notebook
Blinking file folder with question mark and a DVD is stuck in it
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the mac, hold the mouse button during 20 seconds to eject the CD, then insert you installation DVD (leopard). Reboot the Mac again, and hold the "C" key. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Jun 10, 2009 | Apple MacBook Mac Notebook
Display screen does not work
First of all, try a restart with the monitor attached.
Secondly try going to the system preferences panel- It should be in the dock - the icon with the apple and the light switch.
Try to "detect displays" and see if it comes up in the menu and if the screen responds..
Let me know what you find out.
Jun 03, 2009 | Apple PowerBook G4 Mac Notebook
The screen is half blue
You many need to reseat the Apple DVI to ADC Adapter that is connecting your Apple Cinema HD 23" to your Mac.
If that adapter is not properly seated, it can cause a color distortion with the display. Also, if the adapter is damaged, that can also impact proper resolution and color balance.
To try and resolve this issue for you, I have a procedure I would like you to try:
I am going to have you take your Mac into Safe Mode to see if we can't isolate what may be affecting your display's resolution.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Here is an additional support reference for troubleshooting Apple Cinema Displays color or distortion issues.
Apple Support Link:
Calibrating your Apple Cinema HD Display for color accuracy
This should help. If it does not let me know.
Apr 24, 2009 | Apple Cinema HD 23" LCD Monitor
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
312 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
